Old 06-23-2007, 07:21 PM
Department X Department X is offline
Question oil restrictors
I got a 428 that was rebuilt by a shop a few years back just getting a round to cranking it up. It has a comp hydrolic roller 230/230. I remeber the builder put restrictors in one side of the block in the lifter bores and the other side he restricked one passage that controled the the lifters on that side. My question is should I be running restrictors on a hydrolic roller? Back then every one did it because there was not a lot of retrofitted street rollers, manly race stuff. If I should remove them were do you think he put the one restrictor that controls a bank of lifters?
Old 06-23-2007, 07:39 PM
BDHABT's Avatar
BDHABT BDHABT is offline
I wouldnt use restrictors with a hydraulic cam.
Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 06-24-2007, 03:37 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
My Crane hydraulic roller lifters are designed to not require any other restriction. I imagine that Comp's and Crower's are the same.
I'm just guessing- that he probably put a restriction into the passage in the front block face that feeds oil from #1 main up to the front of the passenger-side lifter gallery.
Old 06-24-2007, 09:22 AM
Thanks Jack, is that a pipe plug or a press in passage?
Old 06-25-2007, 02:08 AM
I have no idea how someone blocked that passage. If lazy-me were doing it, I'd probably just drive a tapered aluminum plug in from the main saddle end.
Old 06-25-2007, 03:09 AM
Karch Karch is offline
I had restricters in mine when I was running a solid flat-tappet, and was told to remove them when I switched to an HR.
I took them out while the engine was still in the car, and dropped 4 of them!!!
Man, was I concerned...but I was able to fish them all out with a magnet...thank goodness for the windage tray.
How many of you have driven over 340?
Old 06-25-2007, 05:57 PM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
pontiac jack would love to see THAT HEMI!!!!!!!!!!!!!!!!!!! pontiac style.
The restrictors should be threaded, HYDRAULIC means needs or uses oil. so i would take them out. Id check all possible passages so NOT to miss any. usually a threaded plug is used take your allen wrench & magnatize it, & you wont dropp your plugs.
Old 06-25-2007, 06:23 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
I restricted that passage on my sprint boat engine. Just tapped the passage for a threaded allen set screw with a drilled restriction and screwed it in (deep enough of course)
Working on going faster (and now staying dry at the same time !!)
Old 06-26-2007, 03:07 AM
Originally Posted by SWEETJUDGE
... would love to see THAT HEMI!!!!!!!!!!!!!!!!!!! pontiac style.
wallaceracing.com has a copy of McCarthy's PE article about my hemi- search for 'hemi'.
Old 06-26-2007, 03:11 AM
Many times, lifter bore restrictors are made from brass or non-magnetic stainless steel screws, especially in aluminum blocks.
Old 06-26-2007, 11:37 PM
Granted, but I purchased a box of 50 1/4-20 or 1/4-28 set screws with a nylock patch almost 20 years ago, and drilled them on a mill with an 0.030" or so cobalt drill bit.
The ones I did were magnetic. I never thought of using brass, and would not use stainless, as there is absolutely no advantage to using stainless.
But, I do understand that if someone were to have stainless or brass, they could have this problem. Obviously there's a fix for this, but it's labor intensive.
Old 06-27-2007, 12:54 PM
thanks guys for the respones been out of town for a few days. I was hoping to hear that I didn't have to go into the block but it's better now before I put it in the car
Old 06-28-2007, 12:53 AM
My post#10 about non-magnetic pieces was meant as a 'caution note'- we tend to think "If I drop this, I can fish it out with a magnet". I've learned to take extra care when removing non-magnetic stuff. When I was competing, I wound up changing a number of fasteners from stainless to plain steel, if they were part of "at the event" maintenance.
