Old 07-06-2007, 09:55 AM
Steveski Steveski is offline
Default A/C Not Blowing Out Dash
What is the most likely cause of the air not blowing fully out of the dash vents on high on a '79 T/A? A bear to get to the cause or air door in question?
Old 07-06-2007, 01:52 PM
getmygoat's Avatar
Default vacuum
Have you verified the vacuum hose from the engine to the firewall is connected well and there are no leaks in that hose?
You could also have a clogged check valve.... have you checked it?
Old 07-07-2007, 06:44 PM
T.Weber's Avatar
T.Weber T.Weber is offline
Steveski,
Dumb question here but did you have the motor out of the car recently and if so did this problem occur after that? Also you said the A/C wasn't coming out of the vents are you getting cold out of floor heater vents? The reason I ask I had a 72 Cutlass that the A/C was coming out of the floor (heater vents) this problem started after I rebuilt my motor. Turns out there was a small plastic vacuum storage canister mounted on the firewall and I hooked the vacuum lines to the vacuum canister wrong. I flipped the hoses around and problem solved. Cold air out of the A/C vents.
Old 07-09-2007, 06:20 PM
Geeto-Tiger Geeto-Tiger is offline
As the others have recommended, probably a vacuum leak. For regulatory reasons, it is mandatory that every vehicle provide a defrost function. As a result, most systems were designed to default to defrost when a vacuum leak occurred.
Old 07-10-2007, 01:02 PM
engineer engineer is offline
just feel where the air flow is coming from. Defrost, floor, dash or a combination. Sounds like vacuum, or doors or vacuum diaphram
