Old 07-06-2007, 10:20 AM
Steveski Steveski is offline
Default A/C Not Blowing Fully Out Dash Vents
What is the most likely cause of the air not blowing fully out of the dash vents on high on a '79 T/A if the fan is working properly? Is it a bear to get to the cause or air door in question?
Old 07-06-2007, 01:16 PM
BAD2000TA BAD2000TA is offline
You might be able to access some of the cables and flapper doors if you pull the glovebox out. You'll have access to the top of the A/C duct box. Maybe one of the cables came off. Good luck.
Brian
2001 Pontiac Trans Am WS6, 6-Speed, LS6 block, TEA LS6 heads, 4" SCAT forged crank, SCAT H-Beam rods, 226/234 cam, McLeod RST clutch, SLP Lid, SLP Power Flo Catback
1980 Pontiac Trans Am Y-84 Bandit WS6, 455 (.030 over), #96 Heads, Hedman headers, Wolverine 234/244 cam, Performer intake, Holley Sniper
"Need a car to run blocker. Speedy car. Speedier than that....."
Old 07-06-2007, 02:44 PM
evil455's Avatar
evil455 evil455 is offline
make sure the main air duct under the dash on the passenger side isn't broken anywhere and is connected properly
1980 Pontiac Trans Am...restored to original
1981 Pontiac Trans Am...street/strip...
1980 Pontiac Firebird/Trans Am...strip...
