Old 07-29-2007, 04:11 PM
86t-type 86t-type is offline
Default Compression test results Help
Guys, whene doing a compression test on a bone stock 75 Pontiac 400 (S Code)what should i be looking for, PSI Wise . I did the test on a cold engine and these are the results:
1)35, 3)45, 5)40, 7)40, 2)40, 4)45, 6)40, 8)40.
Keep in mind this was a cold motor not run for a few days. I understand these are low comp. motors and i guess i am looking for consistancy. This motor has 80K miles on it.
THANKS
John
Old 07-29-2007, 04:41 PM
amcmike's Avatar
amcmike amcmike is offline
Well if it's PSI you are either missing a one in front of those numbers or you have no piston rings installed. Are you sure you did it correct? Need to open the throttle all the way (with the coil disconnected) and let it crank at least 5 times until the gage no longer goes higher.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 07-29-2007, 05:02 PM
SergeF SergeF is offline
Did a timing chain jump?
Old 07-29-2007, 05:09 PM
Get the engine up to operating temperature and try again.
Make sure the throttle and choke blades are both wide open.
Remove all the spark plugs so it will crank fast enough to give you some valid results.
Old 07-29-2007, 05:33 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Ditto this.
That or the valves are'nt adjusted right or are'nt sealing very effectively.
Do a leakdown test,or at the very least take the valve out of the compression tester rig and pump some air into a cylinder and listen to where it's leaking from.
Even cold the numbers should be way higher.
HTH.
This space for rent...
In the meantime,check out the cars HERE.
Old 07-29-2007, 07:07 PM
O.K i think i found my problem. It may be my Comp. tester. I took out the shrader valve and did the test(of course it will not hold the psi in the guage) However it went up to 140 psi. Also keep in mind this is a good running motor. I am just assesing it's condition since the car is new to me.
Even though the guage is not holding the psi the fact i am getting the 140 psi is a good thing.
What do you guys think?
John
Old 07-29-2007, 07:50 PM
Ollie's Avatar
Ollie Ollie is offline
With one cylinder at 135 and one at 145, 140 psi is good for a motor with 80K.
Its ok to giggle and snicker, Dont laugh and point
Old 07-29-2007, 07:58 PM
Yeah,140 would be about what I'd expect for a low comp 400 that has some miles under it's belt.
I would replace the schrader valve in the test rig with a new one and retest,as stated testing the car warm is prefered vs. testing it cold.
Though a leakdown test is still a much more accurate assesment of engine condition.
