Old 08-01-2007, 05:40 AM
A390GT's Avatar
A390GT A390GT is offline
Default 70 executive with front disc brakes
I found a 70 executive in the bone yard with a front disc brake setup. I'm not sure but I think it will fit on my 68 catalina. Can anyone conferm this before I go trying to pull them off. Thanks, John-
I need to know asap.
Old 08-01-2007, 09:02 AM
Stuart's Avatar
Stuart Stuart is offline
Yes, it should be a bolt on affair. I believe you need the spindles as well, along with the master cylinder and related parts. The one potential problem is if the disks themselves are in tough shape, replacements can be hard to find.
Old 08-01-2007, 09:13 AM
A390GT's Avatar
The discs were all rusted and banged up because there are no rims on the car. Are these discs expensive or just hard to find?
Old 08-01-2007, 09:58 AM
jku72 jku72 is offline
I put the '70 Executive discs on my 67 Catalina and it does fit nicely. I did it 7 years ago, and seem to remember changing ball joints at the same time. Not sure if I had too, but its a good idea to do so anyway.
Make sure you also get the Master cylinder and proportioning valve, as the brakes wont work right without them. As I learned.
Old 08-01-2007, 10:00 AM
Stuart's Avatar
My understanding is that no one makes the rotors any more. You used to be able to go to the local parts store and get them new, but now you have to find NOS parts or good used ones.
Old 08-04-2007, 01:06 AM
both, no repro's at this time and about $200 a pop when they do surface.
the ball joints are the same in a pontiac from 65 - 70. no other gm b/j interchanges.
mike
former." --Albert Einstein
- Winston Churchill
Old 08-05-2007, 09:20 PM
kmccrystal's Avatar
kmccrystal kmccrystal is offline
I put on discs from a '70 Bonneville on my '68 Cat. The swap was pretty much straight forward. I have heard that Kanter will/has/might be making the rotors. Check with them about availability. Hate to send you there, they're total a$$holes; but they are the only ones with new rotors I think. Everything else is available parts wise. The ball joints are the same between the original drums set up and the '70 disc. Make sure you get the MC and the small tubing and the little valve thingy below the MC as well. I had new bearings pressed in the rotors just to make sure. Bearings/seals can be purchased from Ames, or the local AutoZoo. I was told to get the pedal assembly and push rod. After doing th eswap I don't think you have to go to this length. The rod lengths are the same, I don't know if the pedal assembly is that critical. If I was you, get them from the junker and try the swap without them first. If it doesn't work then swap the assembly, etc.
'68 Catalina convert. w/ 428, OEM long branch exh, QuadraJet, 3:23 Posi, GP front grille, GP bucket seats and GP tilt.
