Old 08-01-2007, 08:17 AM
Whse 1 Whse 1 is offline
Default Rear harness
I'm installing the rear wiring harness on a 67 GTO and would like to know howit was routed. It has white push in clips taped to the harness at various locations but I dont seewhere they would attach in the trunk. Also I need to know How the dome light harness was routed . This car was completely gutted when I got it any help would be greatly appreciated.
Old 08-01-2007, 10:20 AM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
It routes through the drivers side floor and comes out from behind the rear drivers side seat to the trunk area
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
Old 08-01-2007, 12:22 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
The tail lamp harness routes along the right side of the trunk. You will need a light to find the the retaining clip holes, they should be along the ledge that runs along the right the right side. The dome lamp harness routes from inside the trunk up the sail panel to center of roof. Hope your headliner is not installed.
Scott
Scott
If you always do what you always did
You always get what you always got
Old 08-01-2007, 01:30 PM
Default Rear harnessThanks
Thanks for the info, also does the dome light harness route on the inside or outside of the sail panel/
THANKS AGAIN
Old 08-01-2007, 03:32 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Scott
Maybe a '67 Lemans vert is different, but my rear harness plugs into the main harness right behind the rear seat. It travels along the DRIVER'S side of the trunk, not the RH side as stated.............Maybe GTO's are different?
"XE cam basher"
Old 08-01-2007, 11:28 PM
Your right i am wrong. Thanks for pointing that out . Left side not right
side .
Just call me wrong side Scott
Scott
Old 08-02-2007, 08:01 AM
Thanks every body
