Old 08-04-2007, 04:47 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Default quick rear axle stud question
I'm trying to replace the rear axle studs from stock to 2 7/8 long studs for slicks. '79 Z28 8.5 10 bolt w/stock studs. I have the 0.480 knurl studs but the beveled area just before the knurl seem almost too big for the stock holes. Is this the correct size or do I need to drill out the holes? If so, what size drill bit? Thanks guys. This is also in the brake, rear susp. section but wanted a faster reply. Mark L
Old 08-04-2007, 05:08 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I went to longer studs on my front wheels to be NHRA compliant. I ordered the .480 3in studs and they were slightly too big to pull through. I took them down to the machine shop and had them drill the holes slightly bigger and press them. Cost me about $30 to have both rotors done.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 08-05-2007, 10:24 AM
RAIV55 RAIV55 is offline
If you are going racing I'd highly recommend going to 1/2" studs. IIRC the smallest knurl on those are .531 which would require drilling axles and drums.
Old 08-05-2007, 02:02 PM
92GA's Avatar
92GA 92GA is offline
28 spline c clip axles is another thing to concider if using slicks. It's only a matter of time when you break them not if you break them. Not pretty when it happens. I sure wouldn't want to be running 100 mph and have an axle vacate. Chuck
