Old 08-23-2007, 09:37 PM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
Question wheel & tire combo for '64?
Need some help picking a tire to go on a 15"x7" rally I w/ 4.25" BS. I am thinking the DB 60 series redline radials, 245/60R15 rear and 225/60R15 front. Will this work? Any pics? Thks Tim
Old 08-23-2007, 09:44 PM
I had that exact same combo on my '64 Tempest for a while, same tire sizes mounted on factory 15X7" Rally IIs (4-3/8" backspace).
Sorry, but I never took any pics when I had those on my car but take my word for it, fitting that wheel/tire combo on your car is a slam-dunk.
Old 08-23-2007, 10:03 PM
tripwr1964's Avatar
Thanks B-man! I thought you might have experienced this combo.
Old 08-29-2007, 10:09 PM
tripwr1964's Avatar
B-Man, I ended up with a set of steel rims 15"X7" with 4.5" backspace (going with poverty caps instead of Rally I's). Is this still going to work with 245/60 rear and 225/60front rubber? I have a stock '64 width differential. I was comfortable with a 4.25" or 4.375" BS, however 4.5" BS makes me think. thk Tim
Old 08-29-2007, 11:08 PM
Thumbs up Very cool!
In all honesty, they'll fit even better now with a little more backspacing.
Old 08-29-2007, 11:20 PM
Old Man Taylor's Avatar
A 4.5" backspace on a 7" wheel should be perfect.
Old 08-29-2007, 11:35 PM
Dick Boneske's Avatar
If that 4.5" backspace is right, and I think it is, the rears will fit fine with clearance to spare. The fronts will fit fine, also. Do not be alarmed if the fronts hit the frame at the steering extremes when the car is jacked up. Even the stock tires will touch the frame and/or A arm when the suspension is fully extended and the steering is turned to either the left or right stop. You would never encounter this condition when driving the car.
I often wonder how many GTO, big Pontiac, and Firebirdowners have checked the front tire clearance when the car was jacked up and abandoned their wheels and/or tires when they would have been just fine.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-31-2007, 02:52 PM
tripwr1964's Avatar
Default what do you think about paint?
Thanks for all the help.
Another question. I am working on painting these body color (pinehurst green). Will liquid paint survive the tire installers machine? My original thought was powder coating, however, I am having a hell of a time matching the color.
Old 08-31-2007, 03:16 PM
The new tire machines will not damage the paint on you rims. Just be sure not to use very harsh cleaners on the fresh paint so it doesn't lose its gloss.
BONESTOCK GOATS
Old 08-31-2007, 05:53 PM
tripwr1964's Avatar
ok dick, i wont worry about the tire install and just have them sprayed. thks
Old 08-31-2007, 09:02 PM
Just be sure to let them know that you just spent $$ to have them painted and you don't want any chips in the paint, no rough handling. As Dick mentioned, today's tire mounting machines don't damage the edge of the rims, they don't even touch them.
Since everybody's Momma has a mini-van with alloy wheels, these new machines made for the now-common alloys are way more sophisticated in the way the rims are handled.
Be sure to specify stick-on weights on the inside only too.
Old 09-04-2007, 05:41 PM
tripwr1964's Avatar
Thanks for the advise guys. You've put my mind at ease regarding mounting painted rims. I didn't realize "poverty" caps would be such a costly journey! So I just wanted to make sure someone doesn't screw them up for me. thks tim
Old 09-22-2007, 04:45 PM
tripwr1964's Avatar
Default just got tires mounted
I'll take some better pics outside later. However, here are some in the garage. Took her out for a ride.... Love them. Look great and ride much more forgiving than my 17"er's with 45's! Thanks for all the help guys! Tim
ID:	105623   Click image for larger version
Old 09-22-2007, 04:58 PM
Thumbs up Sweet.
Lookin' good.
Hard to believe how good these cars can look with the stock wheels and tires on them. The redlines really add that extra 'pop' to the combo.
Easy to see why the standard dog-dish caps are making such a big comeback, and not just on Pontiacs.
Old 09-22-2007, 06:13 PM
general general is offline
Tim, sent you a PM.
Bob
Old 09-29-2007, 04:08 PM
tripwr1964's Avatar
General, I sold my torque thrust last week. Tim
