Pro touring F-bodies Two thumbs up
Just got a pile of parts for my 78 T/A from pro touring F-bodies and their parts ROCK They had everything in stock and shipped it super fast. Their Firewall G-braces are based on the old VSE pieces but with some improvements, also got the tubular subframe connectors, solid body mounts,driveshaft loop,swaybar brace,rearswaybar drop links and the solid tie rod sleeves. All the parts fit extreemely well and the finish is excellent . If you have a first second or third gen f body you should definatly check these guys out. Thanks a lot Dave
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
