Old 09-08-2007, 06:49 PM
moparcolt's Avatar
moparcolt moparcolt is offline
Default 1967 Firebird pro street, tubbed, 4-link, Cage
It is hard to classify this one. It is indeed a pro street car but the interior and body have been restored to look very factory. The interior is stock appearing except fot the cage shifter and tach. It has all new chrome and emblems, new paint, new weather stripping and Glass! the drivetrain is completely new and has only about 10 miles on the whole car.
Have PHS packet on this car, was originally 326/auto factory A/C, Verado green with Black deluxe interior
Motor is a Pontiac 400 +.060 (412 cid)
2 Holley 600's on Offy Intake
Racer Brown .510 cam
mildly ported heads
Forged pistons 9.7 to 1 compression
Doug thorley headers
petronix ignition
RobB MC fuel system (pump and filter)
16 Gal cell with sender in trunk
-10 fuel line
all AN style line and fittings from fuel cell to carbs
Aluminum Radiator
Trans TH 350 w/3500 stall TCI converter
B&M Pro Stick shifter
Deralle deep pan with cooling tubes
TCI trans cooler
new driveshaft and u-joints
Rear Ford 9" with strange center and spool 4.86 gear
35 spline moser axles
4 link w/coilover shocks
aluminum pinion support
Front suspension Heidts tubular control arms with 2 in. dropped spindles
69 firebird style disc brakes
Chrome steering gear (center link,tie rods, idler arm,steering arms,brake dust shields)
Fast ratio power steering box
Line lock
adjustable proportioning valve
mopar style aluminum master cylinder
Dot 5 Fluid
33x22.5 Hoosiers on weld pro stars
25x4.5 hoosier front runners
body all steel w/400 hood and all 400 trim
base/clear paint ('07 Subaru Chrystal Grey Metalic)
rear wheel wells streatched 3"
smooth firewall
all glass new except the door glass
all new weatherstripping
new interior, 69 firebird buckets with 67 uppholstry,new headliner,carpet, everything replaced except door pannels,and dash pad!
Painless wiring /whole car
wiring in engine compartment all hidden
autoguage 5" tach with shift light and recall
No radio,not needed! Has radio delete plate!
Much more just ask, could easily be raced if you wanted to. It has all heavy duty parts and would need very little to be raced.
I have a complete photo documentation of the build which took me about 1 year to complete (about a hundred photos) I also have most of the receipts fror everything done to the car. This car is brand new from front to back!!
asking $28,500
Chris 440-636-5509
216-854-0359 Cell
ID:	104162   Click image for larger version
ID:	104163   Click image for larger version
ID:	104164   Click image for larger version
ID:	104165   Click image for larger version
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
Old 09-08-2007, 06:53 PM
moparcolt's Avatar
a few more pics!
ID:	104167   Click image for larger version
ID:	104168   Click image for larger version
ID:	104169   Click image for larger version
ID:	104170   Click image for larger version
Chris Collier
Old 10-08-2007, 07:31 PM
moparcolt's Avatar
bump
Chris Collier
Old 08-31-2008, 01:38 PM
moparcolt's Avatar
http://s248.photobucket.com/albums/g...colt/firebird/
here is a complete photo doc of the build.
It is still for sale!
Chris Collier
Old 09-01-2008, 08:36 AM
Transporter Transporter is offline
Hey Chris, nice car interested in any trades? Thanks Stan
Old 09-01-2008, 10:07 AM
moparcolt's Avatar
might consider a small part of it as a trade but need most of it in cash. I built this with my dad, He paid for am good part of it and I did all the labor. So i need to give him his part back.
Chris
what are you trading?
Chris Collier
Old 08-15-2009, 08:21 PM
moparcolt's Avatar
TTTTTTT
Chris Collier
