Old 09-18-2007, 04:40 PM
Curious George's Avatar
Curious George Curious George is offline
Default Pontiac V8 in a vega or monza
Anyone done this or know what needs to be done? Any help would be appreciated.
Old 09-18-2007, 04:49 PM
Steve Barcak's Avatar
Yes, we have one here at Pontiac Heaven. A late 70s Monza with a Pontiac. I love seeing chebbies with Real Pontiac power! It just makes me smile.
Steve Barcak www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 09-18-2007, 09:27 PM
GonicGM's Avatar
GonicGM GonicGM is offline
I believe there were two Astres (Pontiac Vega) with Pontiac power, real grey on my memory here.
Padre's Faith, RAV powered?
Super Chick, Nunzi?
Check the HO racing books or Pete mcCarthy's
Gregg V.
Old 09-18-2007, 10:50 PM
The baddest Astre ever was driven by Burt Straus from Canada. I think Toronto. It was called 'Chief Chilly Willy'. It was a for real NHRA PRO Stocker with Pontiac power! 1972-74 era. High port exhaust, split Holleys, Lenco, all the good stuff. It was actually low qualifier at one of the NHRA meets ( I think Englishtown).
Another 8 second Astre was Rudy Diphus (spelling of last name wrong, sorry, I do not know correct spelling) from the nor Ca bay area. High ported Ram Air V, Lenco, etc. This was in the mid-late 70s.
Both cars have been featured at least once in a national magazine.
Are you going to build one or just curious?
"Real Pontiacs only...no corporate nonsense!"
Hosting-
Phil 2:11
Old 09-19-2007, 10:41 AM
A guy at work wants to build one. I told him I'd check here.
Old 09-19-2007, 04:34 PM
6704gto's Avatar
6704gto 6704gto is offline
monza alreay came with a v8 and the vega is goin to be tight i knew a guy who had a small block chevy in it
Old 09-20-2007, 11:03 AM
BR57's Avatar
BR57 BR57 is offline
I suspect this Poncho Monza will be for the strip but I had a mildly modified steet V8 sbc Monza in my youth, it was pretty wild though, btw the Vega shop manual is the Monza shop manual so the cars are pretty much the same. If I had it to do over again I would be pulling the inner fenders out, probably stating the obvious. Hooker made a 3 or 4 piece header back then that looked like a bunch of snakes, that was a s.o.b. to install that required jacking up the motor. Also had to jack up the motor to change the plugs on the driver's side. Ran short pipes from the collectors to two turbo Corvair muffler with dumps just ahead of the rear axle. You should also be thinking about changing brakes since the factory discs up front are not finned and I just burned up pads and rotors and calipers. Left the car in stock stance with 70's and actually pretty nice OEM aluminum wheels. It was a 75 that I had from 79-81 and it easily handled the new Corvettes, Camaros and Mustangs of the day. That car generated a lot of heat inside too.
I once offered to boost a huge Buick Estate wagon that was dead in the water and the owner, a middle aged executive just laughed, until I popped the hood and he said man you could power a small town with that. We hooked up the jumper cables and Needless to say the big 455 fired right up.
Old 09-20-2007, 01:05 PM
engineer engineer is offline
friend had a BBC in a vega, but needed major surgery to get it to fit.
Old 09-20-2007, 04:26 PM
I remember seeing a BBC in a Monza before and if it is that much work to fit, the Pontiac may be just as difficult. It would be mostly a street drive sleeper kind of vehicle. My coworker is looking for an easy drop in and I told him it would likely be more involved than that. Since he is looking for a simple transplant I think I'll advise him to; I can't believe I'm saying this, stick with an SBC.
Old 09-20-2007, 07:26 PM
BR57's Avatar
Also forgot to mention that I had to beef up the front end, HD springs and shocks otherwise he'll be collecting pebbles with the front end. A lot of weight out front with the sbc so a Poncho is probably more. The fun part was the way you could break the rear end out on corners....and smoke, almost embarrassing at times. I highly recommend doing the V8 but just keep in mind the pitfalls. In my parts Pontiacs did come with Chevy engines badged as Pontiacs so if he wants an air cleaner decal that says "Pontiac 350 Astro Flash", I have some.
Old 09-20-2007, 09:51 PM
GonicGM's Avatar
That's unique!
Gregg V.
Old 09-20-2007, 10:02 PM
BR57's Avatar
Originally Posted by GonicGM
That's unique!
Then how about this one then? BBC or should I say BBP?
Old 09-21-2007, 02:33 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Wow- it'd be worth building a 427 c.i. 390 HP Pontiac just to be able to use that decal!
Old 09-21-2007, 12:56 PM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
We put a Buick Stage1 455 and a Buick 430 in a Vega. Slightly wider than the Pontiacs, but they will fit.
We cut the lower radiator support and installed a truck radiator at an angle to provide more room and cooling capacity. Left the front suspension alone, and swapped an 8" ford rear under it after the stocker stopped moving the car.
I have a 75 Buick Skyhawk and a spare Pontiac 400 that I want to mate, just havent had the time. It would be more strip than street, and probably a back half just to fit more than a 215 60 15 under it. Not sure what to do about exhaust, we used factory manifolds on the Buick. Motor plates look to be easier than factory style mounts.
Upgrading the brakes would be a good idea, and the rear will definitely need replaced. That Buick urged Vega was scary though, would have been quick if it could have hooked. 1/2 mile smoke show.
Old 09-22-2007, 08:05 PM
BR57's Avatar
Here is a link dedicated to the V8 Monza and all the rest of those cars, sunbird, Vega, Astre, Skyhawk, Firenza etc...
http://www.v8monza.com
They are saying do not put in a big block for daliy driver use, strip only because the suspension has to be heavily modified for street use with all the additional weight.
Old 09-24-2007, 10:34 AM
Thanks everybody.
Old 09-26-2007, 11:46 AM
gto65lvr's Avatar
gto65lvr gto65lvr is offline
Theres a guy here in oregon that has been racing a astre wagon for many years with poncho power. Usually at the Tiger run and various strips. He is well known in the pontiac crowd over here, except hahaha I don't know who he is I have only seen the car at tiger run
Eric
CURRENT CARS
68 Firbird 400ci convertible
Old 09-28-2007, 12:37 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Default My 1980 Sunbird
It fits ok, the biggest limitation is hood clearance if you must run the stock hood. I have 2-1/4 headers in there.
Lynn
http://forums.maxperformanceinc.com/...d.php?t=403347
Old 09-30-2007, 10:28 PM
goquick's Avatar
goquick goquick is offline
Wow !! I've not been online enough lately!!! (been kind of busy getting something new ready. )
1975 and later Astre, Vega, AND monza bodied type cars had thinner frame stampings up front than 70-74's. As for not running a bigblock with an 8-71 on the street because of weight, you can, (I did for 2 years!). It's not like the front tires get as much time on the pavement as the rears, so they last fairly good. What you do want to do is take the entire front clip off (fenders, bumper, brackets, etc.) and run a 2x3 mild steel thru from the front to where the frame begins it's turndown. Weld it in place. Reattach the front end. Use coil over front adjustible shocks. The crossover is too thin, so cut it out, add either C/M or mild steel tubing from side to side. I attached mine so that when it was welded, it was out of the way of the oil pan, helped support the engine mounts, and was also with an additional tab welded on helped support the lower a-arm. The tab was made from 5/16 steel. The lower a arm bushing was also pushed though this so no front end alinement issues would follow like stock frontend cars have. Another bolt on tab goes on the outside for the a arm bolt to pass though so the nut and washer helps hold it all in place.
My current Vega isn't a good one to try and relate to a stock bodied car, as my engine is set back and my firewall is behind the base of the windshield.
Checkout www.myspace.com/byronsracing
In my pictures section there is a few pictures with the hood off and you can see how this car is done. I think it's a good idea to always put a Pontiac engine in these cars as it drives the chevy crowd crazy.
You will most likely need to relocate the steering shaft some, but it can be done. Lynn may have a better handle on that. His Sunbird (which if I ever had the money for wouldn't have stayed his!) was built under tighter rules than any of mine.
Old 09-30-2007, 10:40 PM
goquick's Avatar
btw Curious, a sbc isn't any easier to install than a Pontiac V8! They all take work! Now if he wants easy, wrong car altogether.
