Old 10-03-2007, 07:57 PM
Mark1968 Mark1968 is offline
Default Old plumbing, Galv pipe
My mother has just bought a house that had been sitting for some time. Unsure of how old the house is, but it has knob and tube and all the water supply from the meter into the house is galv. pipe.
Theres something about this stuff, when theres no water in it for a period of time, and then when the water gets turned back on it leaks like a sieve, everywhere.
Anyone know about this stuff? Anyway I can clean the threads and retighten. Looks like I am going to be running alot of new copper or cpvc
Old 10-03-2007, 11:11 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Replace it all, and throw it far away! We replaced all our galv. shortly after moving in. It corrodes from inside, and then bursts.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 10-03-2007, 11:22 PM
george kujanski's Avatar
Since it has knob and tube, the galv pipe is undoubtedly all corroded inside. You need to replace all of it.
George
Old 10-04-2007, 02:36 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
I agree with the others...........replace it. If you dont replace it now then you will be replacing it later.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 10-04-2007, 12:45 PM
boater bill's Avatar
boater bill boater bill is offline
While you are replacing the plumbing call an electrcian to upgrade the wiring so it will not have problems or burn down.
K&T is a nightmare.
Old 10-04-2007, 01:13 PM
TTAJay's Avatar
TTAJay TTAJay is offline
Typically the horizontal runs of galvanized piping are in far worse shape than the vertical runs. It has something to do with the water sitting in it. I've replaced most of mine but I still do have some vertical runs that aren't in bad shape... yet. Someday I'll get around to replacing it.
Jason Stanco
Albany, N.Y.
Former owner of '89 TTA #1102
Too Many cars... so little time
'74 455 TA
'76 455 TA
'77 400 TA
'79 400 TA
'30 Model A Tudor
Old 10-04-2007, 06:08 PM
Jagtec1's Avatar
Along with all the stuff the water damage ruins!!
Darin
9.81 @ 136.39MPH
Old 10-04-2007, 06:36 PM
RacerBrown RacerBrown is offline
I also agree with the others ,replace it all!! If your going with the copper I think that there are 3 grades that are used in the house "K-L-M" I would not go any lighter than "L". As far as plastic goes CPVC is used (on my job) for chemicals.
Old 10-04-2007, 07:15 PM
Thanks for the reply guys. Although I didn`t want to hear it, guess I`ll be doing lots of repiping in the coming months.
Old 10-04-2007, 07:38 PM
Pearlbluebird's Avatar
Pearlbluebird Pearlbluebird is offline
The insurance Companys here force you to replace Knob and tube wiring and galvanized plumbing or they will cut off your coverage. You are wise to replace it anyway.
A second class drive is better than a first class walk.
Old 10-04-2007, 10:02 PM
carcrazy carcrazy is offline
Galvanized pipe has a life expectancy of about 50 years. Typically hasn't been used since the 50's. It is at or past the end of its useful life. Even if you repair it, it will fail again in short order. The consequences could be financially significant. Now since you mentioned the presence of knob and tube wiring-get an electrician, fast! This type of wiring has not been used since the 30's it is well past its useful life. Many insurance companies will not insure a house with this wiring!
Old 10-05-2007, 07:38 AM
redeyedfly's Avatar
redeyedfly redeyedfly is offline
M is just fine and quite a bit cheaper than L or K. It is the recommended grade for residential water supply. The other grades are for buried service runs and other applications. The difference in grade is the thickness of the wall, but copper does not corrode like your old galv did. M wall thickness should be good for well over 100 years. But if you're looking for a 200 year water system, spend the extra for the L. No I am not exaggerating.
Almost no one uses CPVC. It leaves a taste in the water. PEX is the way to go for plastic.
Old 10-05-2007, 12:21 PM
sdx455's Avatar
sdx455 sdx455 is offline
Ever look inside old galv pipe . you wont believe you have been drinking water from there .That will make you want to change it .......
73 GTO 455 TKO 600 3.90
