Old 10-09-2007, 01:37 AM
temp77's Avatar
temp77 temp77 is offline
Exclamation Disc Brakes Conversion
I hear that an S-10s disc brakes will fit on the 67 firebird with no mod's need. If this is true what year and make of the S-10 do you need to do this?
Old 10-09-2007, 10:30 PM
SD421's Avatar
SD421 SD421 is offline
This last Sunday I tried mounting my vintage (14x7) Torq Thrust American Racing Wheels on my father in laws 1988 S-10.
They fit. The rotor diameter is 10.50". Now whether the rotor and caliper bracket will mount to your spindle or the whole s-10 setup, I dont know.
Id contact Mark@ www.Scarebird.com He'll set you up.
-Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 10-10-2007, 12:18 AM
70.5_firebird 70.5_firebird is offline
If you are talking about rear disc brakes, here is the article at High Performance Pontiac.
http://www.highperformancepontiac.co...kes/index.html
It is a bolt in swap with NO machining required for 10 and 12 bolt gm diffs. You will need to pull the axels to get the backing plates off/on. You can use 4wd or 2 wd parts, only difference being in the backing plates positioning of the caliper. 2nd gen firebirds use 1 2wd backing plate and 1 4 wd backing plate because of the staggered rear shocks. This swap uses 98-02 chevy/gmc truck/suv rear disc parts.
Old 10-10-2007, 04:42 PM
temp77's Avatar
Thanks guys, I think that is going to help me. My goal is to do disc brakes on the front and rear but I was wanting to do it cheaper buying the kit that they want a grand for the front brakes and $500 for the rear. And S-10's are a dime a doze4n. By the way SD I am form the bay area my self. Concord and Benicia is were I grew up and in the Navy now. Thats why I am in Whidbey Island now. Thanks again guys!
Old 10-13-2007, 02:32 AM
SD421's Avatar
Well bud, Im in the Marine Corps Reserve over in San Jose right now and I grew up in Walnut Creek and now live in Concord. Small world! Where the hell is Whidbey Island?
-Don
1966 GTO
KRE Tri-Power
Old 10-13-2007, 02:39 AM
Fishin2Deep4U's Avatar
Fishin2Deep4U Fishin2Deep4U is offline
-Don
WA State.
Dave
Old 10-13-2007, 03:14 PM
umm, 67-69 Firebirds are rear steer, while 82-95 S-10's are front steer.
What size rims are you running?
Old 10-16-2007, 02:16 PM
temp77's Avatar
Default scarebird
right now I am funning 15's. I am still working on the body but want to get brakes do after the body.
Old 10-16-2007, 07:00 PM
You have many options running 15's...
Old 10-16-2007, 09:58 PM
SLAYTO SLAYTO is offline
Temp, good luck with your disc brake upgrade! I am doing the same except on a 68 camaro although I am using 79 seville rear caliper brackets ws6 calipers and rotors and standard single piston front setup from a 69 camaro BTW my younger brother is stationed at Whidbey Commander David Slayton USN.
Old 11-12-2007, 07:35 AM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Do you know the GM part numbers for the correct backing plates(one 2wd and one 4wd) for use on a 2nd gen ta? and which side uses what
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 11-12-2007, 11:14 AM
myckee's Avatar
myckee myckee is offline
I posted the info you need in this thread:
http://forums.maxperformanceinc.com/...d.php?t=518454
I also had pics of the install, but the site hosting the pics closed and I haven't had a chance to find another place to upload them.
