Old 10-22-2007, 01:54 PM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
Default no oil pressure on driver side 350 Chevy priming
i started priming my 350 Chevy today and im only getting oil on the pass side rockers,,, driver side is dry,, im using a priming tool for a Pontiac v8,,ran the drill for 2mins at 45psi
so whats going on,, do i need a different priming tool?
Old 10-22-2007, 02:12 PM
sandmanjoe's Avatar
im sorry,, im getting oil on the driver side,,, no oil on the passenger side.
Old 10-22-2007, 03:10 PM
buds56's Avatar
buds56 buds56 is offline
I had the same problem with a 327 and I took an old dist., ground the teeth off the gear ,welded a socket to the top, installed it and got oil pressure right away. I believe there is a passage that the distributor seals off.
Old 10-22-2007, 03:47 PM
sandmanjoe's Avatar
yup., it needs to pressurize,, im not sealing the hole. i ordered a new tool with the cap
