Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 10-27-2007, 12:03 PM
cnc's Avatar
cnc cnc is offline
Default 70-73 full quarters aftermarket
Anybody ever used these guys and or there panels...http://ultimateperformancecar.com/Pr...Firebird2.html
I was just doin a serch on Google and found them the Full quarters look ok not sure lookin for some advice
Scroll across the top of the little boxes and it shows all the parts available quarters r at least half way through ....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 10-27-2007, 01:10 PM
1066K from DII (DynaCorn) are '70 1/2-73 CAMARO 1/4 panels.
Camaro 1/4 panels have totally different contour. Eventually............ some entity will reproduce the '70 1/2-73 FIREBIRD full 1/4 panels. Hopefully this will be a high quality effort, not another botched product.
On a similiar note, the repro '70 1/2-73 Camaro tailpanel also has different shape & contour on the lwr "roll pan" area & will not work as a piece to trim & make a patch panel for the tailpanel on a '70 1/2-73 Bird.
Old 10-27-2007, 01:14 PM
cnc's Avatar
cnc cnc is offline
Your right the closer i looked at the marker light i see the diff got my hopes up i guess
Smilies are Off
