Old 10-28-2007, 02:35 AM
loggerhead loggerhead is offline
Default Air/Fuel Ratio VS. Horsepower
Let's say you have a Pontiac 455 that's built for 500 HP. Engine runs great, but
tail pipes are soot black. How much Horsepower could one be off because of A/F Ratio?
(Rochester Q-Jet for Carb.)
Thanks,
David
Old 10-28-2007, 05:23 AM
amcmike's Avatar
amcmike amcmike is offline
You can lose as much as 10% depending on how rich it is. But black soot on the tailpipes doesn't mean it's necessarily over-rich under wot. You need to read the spark plugs, monitor a/f ratios and/or exhaust gas temps.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 10-28-2007, 09:48 AM
PONTIAC DUDE's Avatar
Post
Could be the power spring for the metering rods isn't right and rich at idle
Old 10-29-2007, 08:03 AM
77birdman's Avatar
77birdman 77birdman is offline
Are you loosing any oil? Does the PCV valve have oil in it?
I had the same problem with my 350. Wound up having bad machine work, oval cyclinder walls.
Can do the talk, can't do the walk......therefore need deep pockets
Injection is nice but I rather be blown
If you got it flaunt it, if not fake it (Snoopy)
Original 1977 Firebird / Welded tube frame connectors
TH350 with shift kit / 400 bored/stroked to 455 by PDude
OCD=Waxing and polishing your oil filter
SICK=wetsanding your exhaust pipe
