I bested my last time of 11.75 with a 11.45.Only change I made was installing a line lock.This enabled a better burn out.60ft went from 1.815 to 1.675,mph remained about the same 116.8 to 117.2. Also ran a Rochester 800 this run and a over rich 830 QFT
back in July's 90 degree heat.Not a good comparison between carbs due to the 20 degree difference in temps.Though I did bring my recalibrated 830QFT dp with me to compare against the Rochester.Only was able to make that one run and was ask to either slow it down or get the required safety equipment.Had fun.So now what is a good roll bar for a sec gen firebird?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Can't answer your roll bar question but wanted to congratulate you on your new best - very nice. The humidity drop is also helping our times as well. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Contact Dave at www.pro-touringf-body.com He is a member here, I believe Pro-Tour79
I recently bought one of his rollbars for my 78 T/A.
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project |
Congratulations, Joe. Curtis and I hope to get out to the track in a week or two to take advantage of the improving air. Hopefully see you then.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far... |
I could have made 15 passes yesterday.There wasn't many racers.I may go next week and try out the 830 QFT for a one time pass.
Johnny,you have any pics of that rolebar from pro-touring?Im in the same boat and need a bar.
9.81 at 139.89mph 3400lbs Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS! 370cfm butler eheads port matched victor 1095 king demon 4.30gear,th400 MICKEY THOMPSON DRAG RADIAL tire
Everything I've seen and read about those roll bars from that outfit indicates they are not NHRA/IHRA legal for competition use.
My understanding is they are a "street" style deal. I strongly advise anybody even considering this undertaking go out and buy a rulebook and read it very closely,or you will be wasting a fair amount of time,money,and materials on a bar that wont pass even a cursory tech inspection.
Yes, i was looking at them.I have dealt with him before,i have his control arms and he set me up with a qa-1 suspension.Dave is a great guy to deal with,ill have to give him a call.
There new bars are listed as nhra legal.
FYI:This info is'nt necessarily 100% current,it's from an older rule book.
Again,I strongly advise you take it to a pro to have this done right,or get a kit from a respected chassis outfit and use the rulebook and follow it to the letter! And do note,a roll cage has even more complex rule requirements than the simple roll bar does. HTH. |
Competition Engineering bars are pretty good.
68 Firebird Are you running with the wind or breaking it? |
Bret,
I talked with him at length on that and have a rulebook here. His 6 point bars are NHRA legal, his 4 point bar like the Jegs and Summit kits are not.
Still I strongly advise getting the rulebook and reading it closely,as poor execution of the bar installation can fail the bar as fast as incorrect materials or improper design or such. Lots of details to remember that people dont always think about as a first timer. |
I was'nt aware they had been added to his line-up... But just advising others to use the "pro-tour" bar is misleading,a fella may think the 4 point bar would have him covered if somebody did'nt bother to point out what exactly defines "legal". You guys gotta be careful giving advice on things related to tech certification,especially if you have'nt been thru a ton of that stuff yourselves,it's real easy for a guy to get some lame advice here and have it cost him a whole bunch of time,effort,money,and materials if he takes the wrong advice as gospel,especially when the printed gospel is readily available for a small fee (NHRA rulebook is the best money you can spend on the subject). This is'nt something to take lightly,do it once and do it right. JMO/FWIW. |
Thanks for the inf Chief,ill look into it and give dave a call.Here is the new bar listed,what do you think?
http://www.pro-touringf-body.com/cha...omponents.html
I think the way the text is written is kinda misleading,it says,and I quote: Quote:
And I would be very curious about the "easy access" 6 point bar pitch,as that has certain legal requirements as well,"drooped" side bars are'nt legal on the drivers side at all,so those are taboo for the most part here,and the swing out side bars require a very specific execution to remain legal as well,the side bar itself has specific execution to be legal,just read the included text I gave in post #11,it states that very clearly: Sidebar must be included on the drivers side and must pass the driver at a point midway between the shoulder and the elbow. I would advise you discuss that subject with them,as to what defines "easy access",I dunno,my roll bar on my A body makes it real fun to get in and out (but I'm a hefty fella),I even put in a quick release steering wheel to improve entry/egress on mine,I cant imagine how tight it must be with a bar/cage in second gen F body... I feel the pro-tour six point bars would be a fine enough kit for the most part likely,would really need to see one installed in a car for a real opinion. But as I said earlier,if the execution during install is faulty,that can be as bad as using the wrong kit or materials or such,you,as the installer,you have to know and follow the rules as well when installing the bar,and if your not 100% familiar with the rules,you damn well better have the rulebook or a current copy of the rules handy to consult with and make sure your not wasting you time installing the bar incorrectly. There is a process to this,mock up,tack the bars,check the fit,adjust if needed,then final welding and fitting of stuff like seat braces and harness mounts and such,add the bar padding,that sorta stuff. Think before you build,dont rush a deal like this,JMO. |
In fact just starting to price adding a bar/cage for the 500" IA2 project Camaro. I bought one of the SW kits awhile back. Heard though any of the kits can have fit issues. Since mine has no package tray wanted to add bars to the rear spring pickup area.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Joe congrats on your new time. Consider how much weight the bar will add and if you want to go faster.
Tom |
I installed a S&W cage in my 79 bird. My installer told me that the kit needed "some" fitting but I believe they all do.
