Old 11-13-2007, 06:25 PM
Red68's Avatar
Red68 Red68 is offline
Default Value of an "X" Pipe?
Any thoughts on the value of installing an "X" pipe into my 68 GTO exhaust? The car is a 400 HO with Ram-Air, ported heads and Ponti-Action headers, leading into the dual exhaust.
68 GTO HO 4-Speed
67 Catalina Convertible
99 Vette Convertible 6-Speed
Old 11-13-2007, 09:36 PM
65WJ's Avatar
65WJ 65WJ is offline
Not real sure about hp gains. It will equalize the pressure. Eliminates the cackle sound when letting off the gas.
My .02
patrick
Old 11-14-2007, 10:34 AM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
I bought a 2.5" X-Pipe complete system from Pypes for my 462 cid, 68 GTO with log exhaust manifolds. I'm very happy with it so far. Car is a M20 four speed. No clearance problems, not overly loud. I had it installed by a muffler shop on an overhead lift. Quick and easy. All pipe connections were clamped.
With RA exh manifolds and HO, you will probably gain a little HP from improved flow and less backpressure.
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 11-14-2007, 11:45 AM
Red68's Avatar
Thanks Dog,
Does the Pypes x pipe have baffles in it?
Also, you wouldn't happen to have a spare radio connector or harness???
68 GTO HO 4-Speed
Old 11-14-2007, 12:06 PM
Hi,
I didn't see any baffles in the x-pipe tubes that I received. I ordered the standard mufflers for my system. Wasn't interested in the loud ones.
I don't have any spare cables, harnesses or connectors for radios.
Mike
Old 11-16-2007, 05:59 PM
va400bird va400bird is offline
Default X pipe
When we dynoed my rebuilt engine we did a pull with the Pypes 2.5" X pipe and it picked up 20 ft/lbs of torque with no other changes. So when it goes in the car, I'm using the X pipe!
Old 11-17-2007, 09:21 PM
they do add power to the ground but there are two negatives, one is they get in the way especially if you have a stick. two is the exhaust loses that stock low burble at idle.
No question though, good for 10-20 pound feet on the chassis dyno.
Old 11-18-2007, 12:34 AM
Dan Linebarger's Avatar
Dan Linebarger Dan Linebarger is offline
I added an "H" pipe and like the balanced sound.
Men feel younger by driving old muscle cars.
Women feel younger by doing a little "nip and tuck".
Both are expensive and darn well worth it!
Old 11-18-2007, 01:14 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
i bought an h pipe and it seemed to tame mine.... maybee i shoulda tried an x pipe or left it without either
Old 11-18-2007, 07:15 AM
Noel Drach's Avatar
Noel Drach Noel Drach is offline
I dropped a tenth of my 1/4 times with mine.Got it from Dr. Gas
68 GTO Pure Stock Drags 13.38 106 MPH 2006
Old 11-18-2007, 10:52 AM
Red68's Avatar
Thanks to everybody who responded. I was considering the Dr. Gas pipes.
Put an "x" in my vette to replace the factory "H" and saw a difference. Noel, Any clearance problems with the Dr. Gas "X" in your car? Is it a stick?
68 GTO HO 4-Speed
Old 11-18-2007, 03:13 PM
pluto's Avatar
pluto pluto is offline
Red, I put a Pypes 3" with X and dumps on my "68 GTO....picked up over 2 tenths. It is very loud though. Bill
Old 11-18-2007, 05:44 PM
hakansan's Avatar
hakansan hakansan is offline
My car went from 294,1 rwhp to 322,1 and added 39 ft/lbs when I installed a 2,5" Pypes system. The car is an all stock -70 RA4 otherwise. Here is a link to Pypes page with some photos: http://www.pypesexhaust.com/gallery25.html
Håkan
`70 GTO, 370 hp, 3:90, TH400.
Old 11-19-2007, 07:11 PM
Noel Drach's Avatar
Sorry I'm late getting back to you.Yes my car is a stick and no there's no clearance problems.The Glasgo brothers run them on their cars without any trouble.The quality is top shelf.
Old 11-20-2007, 01:30 AM
Red68's Avatar
Done deal! Dr. Gas it is.
68 GTO HO 4-Speed
