Old 11-21-2007, 08:10 PM
raj raj is offline
Default Cast Iron intake question
I have an intake that I've traced the casting number to a 1972 engine. It's a run of the mill 4bbl intake casting #485912. I've heard that some early intakes have very good flow numbers similar to or better than an Edelbrock performer. How does this one stack up vs. a performer? I'm thinking of building a mild 455 with 6X heads.
Old 11-21-2007, 08:55 PM
Kitch428m21's Avatar
Kitch428m21 Kitch428m21 is offline
FWIW, I'm building the same combo as you and from what I've read here, I'll be planting my '70 intake back on. It gives the stock look, and performs very well from what the experts have said.
Old 11-21-2007, 09:17 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
Here's a link to a test done by SD performance with different intakes.
http://www.sdperformance.com/newsStory.php?newsID=44
I think that the stock intake does pretty well in a mild build. It comes down to what the rest of your combo looks like.
Old 11-21-2007, 10:14 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
I'm building the same basic set up, except with a 400 and #13 heads. My intake is a '70 modified to remove both the water crossover and the heat crossover. The plenum and carb mount face will remain stock for now. My heads are ported to Jim Hand's specs (as well as I could) and the intake and head ports matched to the standard Felpro gasket.
I have a Performer on the bench but won't be putting it on.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 11-21-2007, 10:26 PM
raj raj is offline
Hmm...I have to admit the brand I'm most familiar with is Oldsmobile. I can tell you that the stock iron Olds intakes suck compared to the aluminum ones. Doesn't seem to be the case for Pontiac. I'll probably reuse the stock iron intake instead of spending money on an aftermarket one. Afterall, it has no EGR and the divorced choke spring still seems operational.
Old 11-21-2007, 11:14 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
The stock cast-iron Pontiac piece is damn good, especially with minimal modifications. Simply ensure that its runner dimensions match those of the cylinder head intake ports, and then carry that size towards the plenum a few inches to ensure consistent cross-sectional area throughout the entire intake tract.
There's nothing wrong with an Edelbrock Performer in an application such as yours, but I'd suggest installing one only if you're looking run an aluminum intake for appearance sake, or for its dual-pattern carb flange. The gains are otherwise neglible.
Old 11-22-2007, 01:25 AM
A.W.Dille A.W.Dille is offline
I agree with Rocky and have found improvement with the stock intake myself. The 400 in my 71 GTO with the Lunati BMII (.490 lift,292 adv. [email protected], 110 lobe seperation, 104 IC) likes the stock better with my unmodified 670 heads than it did the Performer or my Torker, especially with a 4 speed. 60ft times dropped to the best the car ever did after going with a stocker, 1.80 compared to a best of 1.92 with the Torker and 1.95-2.01 with the Performer. Alot stronger in the midrange, up to my shift point of 5200. Go with the stock, better choice overall, especially on the street.
