Old 12-12-2007, 10:23 PM
DMC24guy's Avatar
DMC24guy DMC24guy is offline
Default 73-77 Bench Seat to Bucket Conversion
My question is as follows:
-I have a 1977 Grand Prix base model with a Bench Seat.
-How involved is it to replace the bench seat with Bucket seats from any 73-77 GP?
(IE, are the bolt patterns on the floorboard different?)
-Will other Pontiac/GM model Buckets seats from other vehicles (IE Firebird) fit in my 77?
-If so, is it a simple install with just bolting up required?
Thanks!
Old 12-15-2007, 01:02 PM
Will take as shot at this since noone has answered & know the buckets fairly well. The horsecollar type A-G body bucket seats & the regular flat top '73+ Abody buckets will have the seat tracks you need... won't need to hunt down & swap seat tracks. 2nd Gen Firebirds & Camaro's used lower profile seat tracks & there are actually several different versions. The '73-77 A-G body horsecollar seats were also different from the deluxe Firebird seats in the design of the seat back release (look at outboard latch area). The large plastic seatbacks are also different as the F & X body versions have the notchs to aid in accessing the seat release. Having pulled a ton of these seats, I'd be on the hunt for a decent pair out of GrandAm, Lux Lemans or GP, they'll have the tracks you need, & all together ought to be easier to find & considerably cheaper than same year (nice shape) Firebird horsecollars.
As far as inner seat track mtg goes, going to have to hand that off to someone who has replaced floor pans in this era of bench seat A-body. I've processed & cut floorpans out of several '73's & '74's, but all have been factory bucket seat cars.
Old 12-15-2007, 02:56 PM
75cancup 75cancup is offline
Talking Alittle work.
If you find a donor car you will need the factory seat brace that goes from side to side , it is spot welded so you will need a good 3/8" drill bit and basic prying tools to remove it . You will also need the one small square plate that has the seat mounting bolt on it .
Take a note pad and take down all the measurements . Clean it all up and remig it to your car.
I have removed these braces too keep them for others doing this but i don't have any right now or they would be yours . mike.
Check the 73/77 abody section maybe someone has a spare set for you.
Ban low performance drivers... Not high performance cars.
Old 12-15-2007, 04:17 PM
lc2 tech lc2 tech is offline
Pm me if you would like a set of the swivel buckets. I bought a set locally but they won't fit right in my project. I'm located in phoenix.
1974 ventura/apollo/GTO mix ) Sold
1992 B4C Camaro -Sold
1987 Buick grand national - Sold
1992 Typhoon- Sold
1989 Turbo Trans Am #1267
Old 12-15-2007, 07:31 PM
DMC24guy's Avatar
Will the bucket seats you have fit in my Grand Prix? Do you have any photos?
