Old 01-05-2008, 07:08 PM
66rag 66rag is offline
Default 63 parts compatible with 64 Grand Prix?
Are the fenders, seats, 4-speed console & dash of a 63 Grand Prix interchangeable with a 64 GP? If not, how different are they?
Old 01-05-2008, 07:10 PM
tom s tom s is offline
fenders are diff,the interior stuff is interchangeable.Tom
Old 01-05-2008, 07:32 PM
stevep's Avatar
stevep stevep is offline
The dash will work, but there is a definate difference, especially over the glovebox. The seats will fit, but the pattern is different. I think that the console is the same.
Old 01-05-2008, 10:33 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Pretty much everything will interchange cept a few specific pieces.
Try calling CRUSHPROOF! 512-386-9889
Old 01-05-2008, 11:28 PM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
Cool The differance
64-63 is a little easier then 63 to 64. the seats should be the same and the console is the same, Dash is differant only on the top chrome piece the bottom of the dash is the same. the dash pad is year compliant too. the differance in the front end is that the 63 uses a hook hinge that bolts to the firewall and the fenders go around this. the 64s have a hood hinge that bolts to the fenders and the fenders bolt to the firewall. will they fit, Yes but the bottom hood hinge will not have a bolt hole on a 63 to 64. from 64 to 63 there is no problem as the bottom hole of the hinge isn't used.
what I did was I put a 64 GP front end on my Catalina wagon and changed the dash for the guages, center console was installed and the inner seat brackets were welded into place. then the shifting hardware was made to fit a T-400, it was bolted up to a 455 and all the stock mounting for the accessories were installed, the GP steering column was installed and a 2nd gen T/A steering wheel was installed, then the wiring was made to fit the console, and 63 lighting harness as the 64 has a bolt in fuse block through the fire wall and the 63 has the wires coming through a firewall boot to under the hood. you need complete front groups as the radiator supports are differant but the bolting locations are the same, the inner fender bolting is the same to the frame and the fender will bolt to the door sill in the same locations. The body line is good to go also.
other then all that, IT'S EASY.......
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
