Old 01-07-2008, 12:19 AM
Tyler E Tyler E is offline
Default Probe SRS piston weights
Just recieved Probe SRS pistons from PPR. They are 455 +.020, or 4.17" I weighed them and thought I'd post the results. They are measured in grams. First set of numbers are the pistons, and the second are the pistons and pins. First piston # matches the first combo #, 2nd piston# matches the second combo # etc.
Pistons: 503.7, 503.6, 503.6, 502.6, 501.2, 503.4, 504.0, 503.1
Piston and Pin: 646.1, 646.1, 646.1, 645.1, 643.7, 645.7, 646.4, 645.5
Anything else anyone wants to know, these will be going off to the machine shop in a couple of days.
Like I said for the rods, I don't have much experience with these, but they look like really nice pieces. Thanks Ace.
Can anyone tell me what stock pistons/pins weigh, and maybe TRW's.
Old 03-18-2008, 10:39 AM
67drake's Avatar
67drake 67drake is offline
I did a search to see if anyone had posted SRS piston weights and I found this thread,so I'll just add to it,for anyone who does a search in the future.
These are the weights from my SRS 400 + .030 (4.15") pistons.
521.0 521.4 520.8 521.5 521.9 521.0 521.3 521.3
Weights are in grams,without pins. Pins ranged from a 142.4 gram low to 142.8 high.
Thanks "Ace"!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 03-18-2008, 11:42 AM
form406's Avatar
form406 form406 is offline
i would love to see a chart of piston weights. press and floating with prices too. it makes it easier to shop for them...i know ross's are around 435...trw's are around 730 i think...just a guess though...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
Old 03-18-2008, 05:01 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Most TRWs are right at 600 gms less pin.
Skip Fix
