Old 01-09-2008, 11:12 AM
79transam79 79transam79 is offline
Send a message via AIM to 79transam79
Default suspension Question
Looking for a company to order a complete front end and rear end bushing kit? Any input on what kits are better, and won't squeak> street driven 79 trans am. Need fast delivery and only want to do it once.
Old 01-09-2008, 12:01 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Talk to Dave at protouring f-body,he will set you up with whatever you need.
http://www.pro-touringf-body.com/
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 01-09-2008, 08:55 PM
6704gto's Avatar
6704gto 6704gto is offline
how bout pst
Old 01-10-2008, 05:29 PM
RASK's Avatar
RASK RASK is offline
It's been a while but I got the complete front and rear suspension kit for my 73 from PST in original rubber. Their kits are pretty good with the exception of the sway bars (many different diameters out there depending on the year and model). Their kits come with aftermarket front sway bar mounts and bushings so I believe I had to find original bushings from PY. I also had an issue with the rear sway bar so I think I reused mine or found another source for those. I got the body mount kit from PY. Radiator core support bushings I got from PY.
'73 Buc Red T/A, 4 speed, A/C, Std Black Interior
"If you choose not to decide, you still have made a choice" RUSH (Freewill)
