Old 01-27-2008, 04:23 PM
edhar47 edhar47 is offline
Default TBI ON EARLY PONTIAC
Has any one put a tbi on a early Pontiac? I know about fuel pressure an return line but what about the distriburtor? thanks ED
Old 01-28-2008, 05:32 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Pontiac Enthusiast magazine mentioned this as a "weekend project".
No info from them on cost, complexity, but I would like to know more, myself.
68 GTO ragtop
91 T/A
69 XKE
Old 01-28-2008, 07:49 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
if you want to use a gm factory tbi setup and ecm, you'll want a distributor with a 7 pin module.
only one ever used from oem is the 301 turbo engine's unit.
i dont know for sure, but it's possible a regular 301 dizzy from 1981 might be computer controlled also; i've never paid any more atention to 301's then the time it took to yank and dump them.
is this thing on?
Old 02-14-2008, 05:41 PM
Rafe LORHO's Avatar
Rafe LORHO Rafe LORHO is offline
Default Holley projection 4 on modified Olds 403
Hello,
I'm using the Holley Projection 4 TBI on my T/A.
The return pressure was too high to start with so I used the vapor pipe going the tank as well as the normal return line - two pipes for return. Had to modify the fuel tank sender unit by adding an extra pipe. You can't get the vapor pipes on the tank to flow in reverse!
In order to keep the right height for the shaker, I used an old Offy 360° inlet manifold and a carb spacer. The Offy was needed to get the engine to rev high as well !
As for distributor, I've stayed with a stock HEI, but I recently uprated it with a MSD kit and external coil (after cooking two stock in head coils !)
Regards,
Rafe
'77 tire shredding 403ci Bandit Trans Am living in France.
Old 04-20-2008, 12:17 PM
Ollie's Avatar
Ollie Ollie is offline
What ECM are You going to use?
If You run fuel only, with a MegiSqurt You can use the stock HEI.
Its ok to giggle and snicker, Dont laugh and point
Old 04-20-2008, 02:08 PM
you can run a stock hei on any efi system in fuel-only mode as long as it'll accept a magnetic trigger (they all do that i've seen).
is this thing on?
Old 03-16-2009, 04:56 PM
Me Notyou's Avatar
Me Notyou Me Notyou is offline
I wouldnt mind reading a step by step on how to do this.
Denn die toten reiten schnell
More doors = more love!
Old 04-04-2009, 03:25 PM
Ollie's Avatar
Start Here.
http://www.msefi.com/index.php
Old 04-06-2009, 01:46 PM
BVR421's Avatar
BVR421 BVR421 is offline
also download the EFI manuals from the Holley website
Old 05-07-2009, 05:22 PM
Bluethunder1975 Bluethunder1975 is offline
I put TBI on my P350 in my 80 T/A..
Bought a Megasquirt EFI kit, built it (took a weekend).
Scavenged a TBI and sensors from a 90 sumthing chev 1 ton with a 350. Cleaned it up, and put a kit into it. I installed the adapter plate for the TBI to quadrajet so it would bolt up to my intake.
I added a Innovate LC-1 wideband to help tune the beast. Its priceless.
Took another weekend to build a harness for it (I used an underhood fuse block / relay from a mid 90s explorer, so I wouldnt over load the existing fuse block. Just used the diagram provided, and a MS EFI harness that had all the wires pre-labled.
I went a little over board the fuel tank, as I converted the 2nd gen TA tank, to accept a 3rd gen sender and pump.
Currently I'm just doing fuel control, with plans to added a pontiac 81 computer controlled dis later on. (waiting on the shelf)
If your good with electrics, its something that can be done in a few good weekends..
All told, it cost about 600 for everything including the wideband O2.
The build was the ez part. Tuning, on the other hand, is another completely different animal.
Old 05-07-2009, 07:41 PM
Ollie's Avatar
Bluethunder
What is involved in adapting a 3 gen pump and sending unit into a 2nd gen tank. Did you take any photos?
Old 05-07-2009, 08:45 PM
Tank baffles from an ninety something S-10 from PNP. very little modding required to make it fit!
Starting to weld in the new sender hole, and tin. I cut out the old vent line "bowl". The new sender has a vent built in it.
And with the sender inplace.
Old 05-07-2009, 10:14 PM
Hawk397 Hawk397 is offline
Send a message via AIM to Hawk397
I've got a Holley Commander TB on my 71 bird, worked out very well! I used a distributor from an 81 301 and I'm running it fully computer controlled.
I ran a dedicated return line and tapped it into the vapor inlet at the tank, worked out very well with good fuel supply and adequate return. I used the stock supply line.
Mark
ID:	167900   Click image for larger version
ID:	167901   Click image for larger version
71 Firebird Custom - Fuel Injected & Over-drived!
Old 05-08-2009, 10:22 AM
Ollie's Avatar
Thanks, Bluethunder.
That gives me ideas for my set up.
Is the sender compatible with the 2nd gen gague?
Old 05-08-2009, 10:47 AM
No problem.. I have 100s of pics from my nut and bolt rebuild.
As far as mods go, it was pretty easy. Probably took an afternoon. The sender was from a late 80s firebird v6 with multiport. I replaced the old pump with a new walbro 255lph.
Once I was done, I plugged off the other lines, and pumped 10psi shop air in, and leak checked the tank. Had a few pin holes that needed some attention.
Yes, the sender is a 0 to 90ohm, which is the same as the one in my 80. I'm not sure about other years though
Old 05-08-2009, 11:46 AM
Ollie's Avatar
Yes, 90 ohms has been a GM standard for years. Do You recall how deep Your tank is? did You have to modify the sender for the tank depth? This is a photo of the sender I have, it is about 10 1/2 deep.
Old 05-08-2009, 11:58 AM
I think i had to take an inch out of the the unit, and I know I increased the bend a little. I had the sender out this weekend, and it looks like I moved the resistor to work in the bath tub baffle. I do know there was not alot of fab work in making the sender work. Just some tweaking to get it to fit.
When I put it together, I tacked the ring in, and put the sender inplace, and set up the float, and pump location in the baffle, while I still had the great big hole in the top, so I could see what it was doing.
Is that a third gen sender? Mine had a real curve to it foward (opposite of the fuel lines)
Here is a pic i found. I wound up turning the baffle 90 degrees from this. The pump is off in the pic as well, But the pick up is near the front of the tank, near the lowest point, around the same location as the original pick up.
Here is a link for a handy guide I roughly used when I looked into this conversion. The section on tanks is about all i used.
http://www.ultm8z.com/EFI%20swapper%27s%20guide.pdf
Last edited by Bluethunder1975; 05-08-2009 at 12:26 PM. Reason: link for efi swap guide
Old 05-08-2009, 12:50 PM
Ollie's Avatar
No, The sender is not a 3rd gen. If I remember correctly it is a 97
Buick. I am going to a GM dealer later to get the "O" ring seal, I will check the pn for the applaction.
Old 05-08-2009, 01:25 PM
Cool stuff..
What application are you going to put this in?
Old 05-08-2009, 02:17 PM
Ollie's Avatar
79 Z code TA 455 with megisquirt controled EFI, Edelbrock EFI intake. Sd Performance prepaired KRE 290 cfm heads and roller cam. Ram Air Restorations 3 1/2 inch oval exhaust.
