Clutch material/advice and PP clamp loads
Hello everyone. I need to preface this thread by saying I'm on a very limited budget. So I'm looking to get the best clutch for the least money.
Option 1: http://www.fortwayneclutch.com/product_2_1.html I use an 11" clutch on a McLeod aluminum flywheel and that's covered by a McLeod scattershield and mated to a Muncie transmission. Race weight is 3800 pounds and I usually launch between 4500 and 5000 RPM. Engine Modifications: '69 400 2 bolt block bored .030 Deck height set to zero #62 Iron heads, milled and ported to flow 275 cfm at .500 lift Stock 10/10 crank Eagle H-beam rods with ARP fasteners Forged TRW pistons Bullet solid cam Mallory Hyfire IV Mallory Mechanical magnetic distributor Edelbrock Performer RPM Intake, top 1” milled out of plenum divider 825 CFM Mighty Demon Transmission: ’69 Muncie has been upgraded with Super Case, Iron Mid plate, M22 wide ratio gears McLeod SFI Aluminum Flywheel 11” clutch Rearend: Dana 60 with 4.10 gears and 35 spline Strange axles and Aerospace disc brakes Tires are 28 x 10 drag radials. |
