Old 02-01-2008, 07:50 PM
trv24217 trv24217 is offline
Default 67 gto no interior and dash lights
Hello, I just purchased a 67 gto and noticed that I have no instrument lights or interior lights. The horn works, the wipers work, the defroster works, all the exterior lights work. What amp fuses are these,also anything might be common to both issues.
Old 02-01-2008, 08:07 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
i just wonder if the switch isnt bad my dash lights werent working and it was the switch but i never checked to see if the interior lights were working since i didnt have them in yet
Old 02-02-2008, 11:32 AM
merlotgoat's Avatar
merlotgoat merlotgoat is offline
If the fuses are good, then Performerrpm is correct to suspect the rheostat and switch within the headlight switch. Do the interior lights turn on if you turn that knob all the way to the left? (I ask because I talked with a young new owner of a Chevelle at a car show who did not know that the interior lights turned on this way.)The fuse for the interior lights is the fourth one from the top of the of the fuse block (4amp). The dome/interior lights are on a separate circuit that includes the brake lights. This fuse is lthe bottom one (20amp). If you have brake lights, then that fuse is good. So check that one soon before you get smashed from behind.
Bob
Old 02-03-2008, 05:03 AM
Thanks for the info I'll give it a looking over.
Tom.
