Old 02-20-2008, 02:08 PM
165th's Avatar
165th 165th is offline
Default 1979 Tenth Anniversary Trans AM (TATA) Forum
I thought it would be fun to start a TATA forum here on the '77-81 Trans Am Tech. Anything Tenth Anniversay related will be game.
There are always questions floating around that are specific to the TATA such as carpet manufacturers, stiping and decal details and interior dyes color options that hopefully when answered will provide a good resource for forum members and owners.
Also, we should have plenty of pictures!
Old 02-23-2008, 11:24 AM
165th's Avatar
One topic that is well documented on the '79TATA 4spd's is that they received L78 W72 engines from the 1978 model year. These engines were held back by Pontiac specifically for the anniversary 4spd cars. No W72 engines were built in 1979.
My car was built in February 1979.
I have been documenting date codes, inspection marks etc. and have determined the engine was probably built in June of 1978. The carb date code is much later than the engine cast codes so I'm curious when the castings had stopped for the W72 motors. The engine was completed 8 months before the car was built substantiating the fact the motor was held specifically for the car.
Here are some interesting date codes on this engine:
Block K087 Nov. 08 '77
Dr. Head K237 Nov. 23 '77
Pass. Head L087 Dec 8 '77
Intake H037 Aug 3, 77
Water pump E248 May 24 '78
Carb 1538 153rd day of '78 or June 3, '78
In the head date code picture note the blue overspray on the valve cover and the 1stQ date on the spark plug wires.
The other pictures identify some great inspection decals and part no. decals. Note the marking on the original fuel line insulation and the original foam ring around the air cleaner.
Name:	dr head k287 6X sm.jpg
ID:	123484   Click image for larger version
Name:	original air cleaner with foam wrap sm.jpg
ID:	123485   Click image for larger version
Name:	carb part no sticker sm.jpg
Old 02-23-2008, 04:25 PM
2manyT/A'S's Avatar
LOVE to to see the detail pics of the unmolested "survivor" cars.
Can we see some more,especially of the booster,master,prop valve area.( I like looking at "factory rust!)
I think you were tuned into our heater hose clamp thread,last month?
Can you give us the "lowdown" on your 10th?
Towers vs. Silver Seals - Van Nuys or Norwood?
Old 02-23-2008, 05:04 PM
2manyT/A'S's Avatar
Default TATA on Ebay
I'd be OK with this one in MY garage!
http://cgi.ebay.com/ebaymotors/ws/eB...212940227&rd=1
Old 02-23-2008, 06:45 PM
2many, I wouldn't mind having it for a back up myself. Did you notice they said it had cruise. I did not see any cruise parts under the hood. Picture underneath looked like pre 74 cross member, hump on both sides for duals.
A friend of mine's 10th T/A has all the cruise parts under the hood, speedo cable through cruise box, vaccum lines, wireing, even got right turn signal lever. It does not have pot on motor. Iv'e checked the vin and it is a 4 speed car, something ain't right.
Mine is not all original but I do have everything to put it back. Can't help but wonder how many of the 4 speed cars are left.
Anyone know about odd ball engine codes and special rear gears on these cars? Something about the first so many made or real pace car models maybe.
Quick-Silver for a reason
Old 02-24-2008, 12:02 AM
roysgoats roysgoats is offline
Great idea for a TATA forum! Here is my question. I have a 79 TATA that i am having a little paintwork done on it and am replacing some decals and pinstripes. I order pinstripe roll from Phoenix graphics and noticed the black portion is wider than the red. On my car most of the pinstrioing is the same thickness. Is it correct to use the pinstripes with the Black thicker than the red on all areas of the car? If this is the case then I am guessing that when my car was painted in the past someone used rolls of red and black that were incorrect. Thanks in advance for your repsonse.
Old 02-24-2008, 12:30 AM
165th's Avatar
2manyT/A's this is a Norwood car. It has Silver Seal worm gears on all 4 heater hose connections. The radiator hoses of course are tower clamps on all 4, with the upper radiator clamp clocked at 2pm (if you facing the car).
Here's a pic of the rust, I mean brake booster and bracket. The red smear on the booster is a paint daub I think, but it's not your typical enamel, it's more of a stain so to speak. There is also a very small blue paint daub barely visible in one picture. The paper sticker on the wiring harness to the proportioner is a W.
The carb picture is great. The part number on the vacuum bracket, and the inspecton mark 'N' and ' - ' on the butterfly is unbelievable considering fuel and fumes pass this way.
Roysgoats, the stripes are different thicknesses. The black is approximately .25" and the red is .13". I'd be curious to know what thickness the Phoenix Graphix stripes are?
Quicksilver, that's a great question about the pace cars. I thought they would have been geared high for the track? Hopefully someone will chime in.
'Restoring' this car will be a lot of work. I'm going to be refreshing all of the parts, but without repainting, replating or replacing. It should look the same when done just neat and tidy. It's tedious and meticulous work as I'm already finding out, but very rewarding.
Name:	brake booster details sm.jpg
ID:	123564   Click image for larger version
Name:	brake MC and booster sm.jpg
ID:	123565   Click image for larger version
Name:	carb details and stickers pass side sm.jpg
ID:	123566   Click image for larger version
Name:	stripe details.jpg
Old 02-24-2008, 09:37 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Love the foam element over the air filter. I'll bet 99% of those dissapeared after the first tune up.
The car pretty much confirms that the prop valve bracket had no paint. Heck I doubt it was even treaded steel. No way the hinge springs look that good & a painted bracket rusts up like that. Maybe some cars had them painted, but not this one.
Nice car!
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 02-27-2008, 12:10 AM
I was wondering if this site would take off or not. I dont know what it is, people either love these cars or just dont care. Iv'e had mine 25 years it's a pretty nice car. Got so many ISCA first in class trophies and jackets got burnt out and quit showing.
Really am curious about rear gears. I changed mine to 3.73 a long time ago. Ended up trading original gears for dual exhaust, that was a mistake. When I got ready to put taller gears back in I couldn't find any. I had all the numbers and ratios written down, it was a 3.5? something. Pontiac dealer checked the numbers for me, good numbers but not availible. Original install only, limited purchase and production, none to be had. The replacement, even under warranty would have been 3.23. I do not have the original part numbers any more but would love to have them. They were lost in a fire.
This is why I was asking about pace car and gear info. A couple of times Iv'e ran into other 10th owners with really nice cars wanting to trade and give boot (lots). They always looked at my vin and had fits. They never would say why.
Still wonder how many 10th 4 speeds left. I know for us the less the better.
Old 02-27-2008, 12:19 AM
W72-Bandit's Avatar
W72-Bandit W72-Bandit is offline
The rear gears for all 79 400/4spd cars were 3:23's. I've never had to look for a set so not sure how hard they are to find.
As for your VIN, is it low or high for 10th production?
I had a 400 10th a few years ago that was built on Jan 3rd, lowest VIN for a 10th I have ever seen......140323.
Old 02-27-2008, 12:35 AM
2manyT/A'S's Avatar
Auction seems to have disappeared?
Looks like Ebay pulled it. Wonder why?
FYI: As I recall,ALL second gen trans crossmembers are double hump style.
70-74 & 75-81 DON'T interchange.
Old 02-27-2008, 08:26 AM
165th's Avatar
Quicksilver, yes, we are all wondering why everyone takes an interest in your vin no? Maybe because it has an 'X' in it? Can you share the vin. no with us? Also, let's see some pic's of your car!
The Daytona 500 was held on February 18, 1979, so all of the pace cars would have been built before that (at least the one's at the show!). Maybe they continued to produce pace car replica's beyond the race date, it would be nice to know.
W72Bandit 140323 Jan. 19 '79 One of the earliest TATA vin. no's known.
Mine 150328 Feb. 21 '79
Does anyone know of a 10th registry?
Old 02-27-2008, 09:38 AM
W72-Bandit's Avatar
There was a registry back in the early days of the internet. I don't know of one currently, may be one out there though.
I have some old docs from Pontiac that have the first and last VIN's from each plant for 10ths. I'll look it up. I believe I read that production was from Jan. through April.
Old 02-27-2008, 10:46 AM
Just got out build sheet. VIN 163024
job sequence number
21724879
sch. no. date
59-0896
04-02
Does show 3.23. It was 20+ years ago when I did gear swap. There was something different about rear. I want to say 3.5?. I was told by dealer that only 100 sets were ordered and installed, no spares. This might have been BS talk by service manager.
Speedo did work right. If one of you can check your speedo gear # I might be able to put this dog to sleep. My # 22GRA-T-BH3, please have a match.
I am brand new to elec. comunication, barely can chicken peck, pictures woh.
Car is in CC storage right now. Wife is going to try to scan some pics. and help with this.
People that wanted my car had X cars.
165th I keep two sets of wheels for mine. One set super polished and one set extra clean. I started collecting them many years ago, when I went to buy a new set for race tires, price was crazy. I put them on every firebird I keep and keep spares. I think Iv'e got enough spare parts to build a whole nother car. Only other 10th car VIN is auto., wouldn't build it for it. Got fair 71 body that will probably end up with WS6.
I will be back!
Clay
Old 02-28-2008, 12:26 AM
165th's Avatar
Clay, I've got a set of original NOS Goodyear Polysteel tires that I'm going to mount on my original wheels for concour showing. My wheels still have the factory clear coat over the aluminum but one wheel is showing some signs of the aluminum wearing through.
I've got a second set of wheels for the Eagle GT's, but the second wheel set is not in the greatest condition. I do plan on polishing the second set for the driver tires. If you have any pristine turbo wheels you'd like to sell, I could use at least 2, maybe a full set if they are perfect.
How do you check the speedo gear number?
Old 02-28-2008, 10:33 AM
165th, I got the gear number off of the build sheet.
I did or do have two new wheels, one tire mount. They are on a wrecked 10th. I live in Laugh-at-it, GA next to a wrecker service and junkyard. Codes dept. made me move the car off the property. Bologna when I have wrecked cars backed up to property line. Rules are rules and I was not going to pay a fine.
The car is out in the country at a friends place. I will try to go look at the wheels and see how they have weatherd.
You can strip your wheels, polish and have them recleared. Better clear coats are availible now and your wheels will look new again. They will hold up better also. Iv'e been wanting to do a set for my car, tired of polishing.
Have you checked the date on your tires? If they are 30 years old it would be OK to show with them but do not drive on them. Not even to the store, especially on your car.
Clay
Old 02-28-2008, 10:55 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I have a spare in the trunk of my TATA that has been powdercoated a shade similar to the original. I like it enough that I'm considering doing the four that are on the car, as well.
(I know.... not very original, but it's one of those personal touches that is subtle and not-so-easy to detect.)
Name:	TATA spare.jpg
Mike
Old 02-28-2008, 10:59 AM
1969T/A's Avatar
1969T/A 1969T/A is offline
It was published in a pontiac magazine about six years ago.
That there were only (1800) 1979 10th anniversarys known left to exist
And out of the (1800) 500 were 4 speed cars.
I rememeber reading in that article they only made
about 12-15 pace cars for parades
By the way. I own the pace car that was at the daytona 500
it was the 4th 1979 10th anniversary trans am made!
I also own four other 1979 10th anniversary trans ams.
The 1979 10th anniversay trans am registry was shut down
about 5-7 years ago.
Old 02-28-2008, 11:30 AM
formula400's Avatar
formula400 formula400 is offline
Hey guys, I just found a really nice 10th unmolested 66,000 miles
Old 02-28-2008, 11:41 AM
mzbk2l's Avatar
Love that green-tinted carpet!
Mike
