Old 02-27-2008, 03:43 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Default Engine assembly checklist
At one time, we had a checklist for the re - assembly of engines. Do we still have that anywhere?
Someone posted it awhile back.....year's ago....(Maybe Old Man Taylor?) and I would like to print it out again, as so I don't forget anything....again......The darn oil pump shaft!
Any luck we still have it?
........I'm just learning as I go.......
Old 02-27-2008, 05:51 PM
77TA406 77TA406 is offline
I think it would also be a great idea to have a checklist of simple modifications that are proven to be beneficial when building a engine. Examples of such would be:
Tapping oil gallery holes in front of block for pipe plugs.
Drilling a .030 hole in rear plug to squirt oil on dist. gear
Replacing steel check ball in oil pump with smaller ball and shimming spring
Clearancing water pump divide plate for proper cooling...
Any other "good to doos" that members care to share...?
Chris
Old 02-27-2008, 05:53 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Chris
Jim hand's book has all this stuff... Pick up a copy.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 02-27-2008, 05:56 PM
Already part of my library.
Old 02-27-2008, 06:49 PM
drevil1's Avatar
drevil1 drevil1 is offline
is this what you are looking for?
Old 02-27-2008, 07:03 PM
Old Man Taylor's Avatar
That's the one. I didn't look at it close enough to see if it had the later refinements. Lee in Texas originally did it and I just added some details.
Old 02-27-2008, 08:29 PM
Rugratman's Avatar
Yep, that's it.
I can't write in Jim's book. This is much easier to use and to double check as you go. I do have the book though and it is a great resource.
Thanks again.
