this was published in HPP in the early 90's. could someone e-mail me a copy?
thanks, bob
69 GTO 11:[email protected] all balls no bottle 406 d-port iron heads 3700lbs all steel |
I have it but I know I could never find it. Call Pete or Jane if nobody can produce it. The # is on his website.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
I have it, I am scanning it in as we speak. Post your email and I will send it to you.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Me too, please [email protected]
www.hobracing.com |
isn't it the same as the one from SD performance that was in Car Craft ?
www.pro-touringf-body.com |
Hmmm,I checked my article collection,did'nt find it,dont seem to recall the article that well either...
All the Pete M. 400 cid articles I have are higher hp builds. Anybody care to post the relevant specs for discussion? I cant expect 65gto69 to send everybody a copy of the article. Maybe post the scans for those interested in this topic.
No mention of Pete M. in the CC article either... |
Good idea but it is too big. The article is 3 pages and in order to have good clarity I scanned them in at 150 dpi 8-bit grayscale, file size is 6 megs or 4.5 megs in pdf format.
If I can post it I will, but I don't know how clear it will be if I take it down a lesser amount. Thanks, Mark P.S. The article is in the April 1992 issue, under "Indian Head" I just tried lowering the scan dpi and the article is still clear, so I will post each page separately.
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. Last edited by 65gto69; 03-14-2008 at 07:49 PM. |
that's the one I remember, ok
Works for pics too. Usually ends up taking a couple of posts to get a whole article posted though. I could probably do it if need be. Email: [email protected] |
Here ya go!!!
Page 1, 2 & 3. I know it is in a microsoft word DOC file but it is the only thin I could use to get the file size down to 300k. If you can't read a DOC file let me know and I will send it to you via email Mark [email protected]
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. Last edited by 65gto69; 03-14-2008 at 08:14 PM. |
OK, here they are in JPEG format
Mark
Goat, I have the mag. Remind me to bring it next time we get together-GET the goat ready, I want to go to the strip! First 5 gallons of race gas is on me.
Great article!
Note the serious increase in power with the Torker II over the performer manifold. Also note the increase in power with the Holley 850 compared to the Q-jet! A very well written article and a great test of the mighty 400. Just imagine what that 400 could do with a set of 300 CFM heads, good rods, a stout solid roller, and a good single plane manifold. |
If I remember right this motor went on to get an offset ground 400 crank, 6.800 rods, roller valvetrain, Warrior intake,1150 and the 670 heads were around the 279 cfm range. It ended up in the Verdoro Firebird that Joel Larkin now runs in Super Stock. I haven't heard where the motor ended up but it did run well.
Only 400cubes and a Hydraulic cam and it really liked the 1 7/8" stepped headers. And people still think 2" headers are "Overkill" for 455plus engines?!!
PHILLYGOAT
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft [email protected] [email protected](Pontiac Heaven) ![]() More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
Another jab at Cliff I see!!
I used the 246/253 duration cam in my 455 way back when.
That was an awesome grind. Went 12.01 time after time. Heres a quick breakdown: Car weighed 3750 at the time. 455 .030 TRWs. No 13 heads,unported.Just a valve job. Stock T-2 intake. Holley 850. 1.75 Heddman headers. Comp Roller tip rockers. Torque Tech 3" exhaust with tailpipes. Generic TCI 3500 conveter. 3.89 gears. Cam was also advanced 4 degrees. Gave alot of Mustangs the whooping;as that cam was very streetable.I drove that thing everywhere. Mark.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
that's a deal twister!!! who's buying the beer??? smitty???
| Closed Thread |
