Old 03-23-2008, 03:11 PM
2manyT/A'S's Avatar
Thumbs up Another "Creampuff" 78 T/A on Ebay
This one is pretty darn SQUEAKY!
http://cgi.ebay.com/ebaymotors/ws/eB...213966578&rd=1
Other than the radio,wheels/tires, it looks "unmolested'.
I'm guessing this one is a "poser" WS6 & W72. Wheels are obviously refinished replacements & the A/C compressor is doing a pretty good job of hiding the P/S valve cover. I don't see any foam on the fuel line.
It's also likely had a waterpump replacement (the factory ones never lasted much longer than the warranty)
I'm surprised it's only bid to 15K.
Sounds like he wants 25K,which I think is a GOOD DEAL,if car is ACTUALLY as nice as it appears to be.
Old 03-23-2008, 08:51 PM
RandyW's Avatar
RandyW RandyW is offline
The bodyside moldings look wrong.
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold)
Old 03-23-2008, 09:21 PM
2manyT/A'S's Avatar
I agree!
ANY bodyside moldings on 2nd gen Birds looks BAD/WRONG.
Those are likely a dealer install.
Old 03-23-2008, 10:30 PM
OhMyGoat's Avatar
OhMyGoat OhMyGoat is offline
The numbers on the odometer appear to be uneven. That would be expected if it had just turned 20,000. Usually the numbers would even out in about 20 miles past the flip. I alway thought that uneven numbers was an indication of tampering.
Alan
Tomorrow is often the busiest day of the week.
Old 03-24-2008, 03:53 PM
Y81all's Avatar
Y81all Y81all is offline
It's definitely NOT a W72. Has the L78 air cleaner base, no foam fuel line insulator. Nice looking car though.
Jon O'Neall
1977 Y81 T/A
W72-400/Auto
"Trans Am! What's your pleasure?"
Old 03-24-2008, 05:11 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Body side molding looks EXACTLY like what my 78 came with from the factory.
Skip Fix
Old 03-24-2008, 08:07 PM
W72-Bandit's Avatar
W72-Bandit W72-Bandit is offline
If its not a W72 then it should not have the shaker callouts. That makes me wonder about the paint being original.
Old 03-24-2008, 11:18 PM
RandyW's Avatar
I hope your's were straighter than those!
My '79 had factory side moldings and they were finished better and were below the body crease not above it.
Old 03-25-2008, 01:23 AM
2manyT/A'S's Avatar
Don't forget that 78 L78 (non-w72's) came with NAKED shakers & it was pretty common in the old days to add the T/A 6.6 decals to the shaker.
My first clue on this one was that the shaker decals look slightly out of position.(non factory installed?)
Old 03-25-2008, 11:30 PM
blk78ta blk78ta is offline
I own a couple '78 TA's now and both have body side molding from the factory. The moldings on the car in the ebay add appear original. Also, in '78 I bought a TA without the W72 (I was told the factory wasn't making anymore W72 with automatic when I ordered mine) option. The dealer said I could just buy the T/A 6.6 decals and add them myself, giving it the appearance of a W72. I'm guessing that is the case here too.
78 Trans Am
Old 03-26-2008, 12:51 AM
2manyT/A'S's Avatar
Went back & had another good look at those moldings and I think that even though they MAY look like OEM moldings,they really DO look kind of FRESH.
They are are just a bit TOO NEW looking for being 30 years old.
That chrome vinyl edge tends to fade with age regardless of UV exposure.
I'll bet they were recently installed by the seller to hide some minor door dings/fender scrapes in the body line.
Would be nice if we could see the build sheet.
That would tell the story.
You might want to scroll down to the bottom of the auction pics & read the LAST (top) question & answer that was posted.
I near "bust a nut" laughing over that one.
The seller OBVIOUSLY has a sense of humor!
Old 03-26-2008, 09:15 AM
autobahn autobahn is offline
Also it looks like the E brake rubber is not on properly(bottom right)
JIM
Old 03-26-2008, 05:33 PM
I will take another look at the body moldings on my TA's. Mine are very low mileage cars and I thought my moldings looked pretty good with no fading.
I know for a fact that my roof drip moldings faded on each of my TA's. Even though the cars have been stored, they are faded yellow.
I also noticed the E brake rubber pad corner not properly on and the answer to the question left from the bidder... That was worth a good laugh!
78 Trans Am
Old 03-30-2008, 04:58 AM
stuta stuta is offline
Default t/a for sale
One thing for sure, you don't see those "hush" panels still under the dash anymore!
Old 03-30-2008, 08:05 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Originally Posted by 2manyT/A'S
I agree!
I don't mind the look of them, but prefer none at all. I went to pull off the original ones off my 79, only to find they where rivited on. The silver centers were oxidized, so I ended up putting on aftermarket moulding to hide the holes that were drilled in.
68RT
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 03-30-2008, 01:27 PM
2manyT/A'S's Avatar
I parted out a 73 Esprit a number of years ago & the body side moldings were installed with clips on studs (the same style studs that hold the window molding clips,rocker triim & belt reveal moldings on)
They were ALSO an aluminum extrusion with a push in vinyl rub strip.
I figure the MAJORITY of these bodyside moldings were DEALER & NOT factory installed.
My 78 came with metal,NOT plastic roofdrip moldings.
I've seen them either way.
I wonder what determined which ones went on a given car?
Old 04-24-2008, 07:34 PM
JBanna's Avatar
JBanna JBanna is offline
Cool
Boy, you guys are tough!!
78 White T/A, Carmine interior, Fisher T-tops, WS-6 package, 3.08 gears, a/c, rear discs. Original 403 with 300,000 miles replaced by new Pontiac 455 (roller everything, 6x-4 heads, Performer manifold, Hooker Headers, Hughes converter, Cliff's Q-jet) - I only get 12 mpg!
