Old 03-25-2008, 09:40 PM
gtopercy's Avatar
gtopercy gtopercy is offline
Default 69 Pontiac GTO
Pro Street 69 Pontiac GTO, non a/c car, Purple Pearl Metallic, working (electric) hideaway headlights, 455 engine bored .030 over, TRW forged pistons, #48 ram air III heads w/stainless steel intake valves, double springs, Harland Sharp roller rockers, Stud Girdles, high torque gear reduction starter, Rock and Roll Engineering 562lift/300 duration solid Comp Cams cam, ARP rod bolts, Nodular crankshaft, lower windage tray, aluminum front engine plates, Holley 780 dp, Eldebrock Intake, air box with K&N high flow lid, chrome valve covers, HEI distributor, MSD 6a, MSD coil, Accel 8.8, wires, new dual electric fans, aluminum radiator, 350 turbo, Trans Go shift kit, new 10" ATI Converter 2800-3200 stall and Hurst 1/4 Stick shifter, Ford 9" rear with 3.89 gears, mini spool, Moser Engineering 35 spline axles, U-joint girdles, new four wheel disc brakes, new disc brake master cylinder/valve combo, new residual valve, 15"x 3.5" and 15"x14" weld wheels, fiberglass bumpers, hood and trunk lid, new ¼ panels, new lower rear window panel, Headman 2" race headers with flowmaster mufflers w/stainless steal tips, 14”x15” weld wheels with new M/T street tires, new aluminum fuel cell with correct sending unit so the gas guage works fine, holley fuel pump and chrome holley filter, S&W full welded ladder bar rear frame kit w/panard bar, AVO double adjustable shocks, 8 point cage with swing our bar and rear "x" brace, all silver faced autometer gauges, monster tach w/shift light, new original factory front and rear door panels, still has factory dash, new stock door panels, new racing style seats w/adjusters, new carpet front to rear, new factory headliner, all new weatherstriping (trunk, door, window sweepers etc…) new Apline rear speakers, original front disc brake suspension, front racing shocks, new front coil springs, front end completely rebuilt, poly bushings, Delco Marine battery, plus much more. The car has about 25-30 runs on it and the engine has about 10 runs. This is a real GTO and not a Tempest/Lemans. I have a clear title for it and it passed PA State Inspection. It ran 11.20's with a tighter converter, I haven’t ran it since installing the loser ATI converter or putting it back on the street. The other converter was to tight. I'm selling because I loss interest in racing, it sat for a couple years in my garage and then I put in back on the street. It doesn't have a rear seat so my wife, son and I can't take it anywhere. It's just not a car I need for this time of my life. I will hate to see it go. TOO MUCH TOO LIST AND A MUST SEE. EMAIL ME IF YOU HAVE ANY QUESTIONS AND FOR MORE PIC'S. Car is located in SE PA. $18,500/OBO will trade for '70-'73 Pontiac Trans Am, Formula, Firebird, '67-'69 Firebird, '77-'78 Black "Bandit" TA.
thx, Percy's Pontiac Parts
Web Page: http://mywebpages.comcast.net/gtopercy/
email: [email protected]
thx,
Percy
Old 03-27-2008, 10:03 AM
gtopercy's Avatar
pics
thx,
Percy
Old 03-27-2008, 10:05 AM
gtopercy's Avatar
pic's
ID:	127135   Click image for larger version
ID:	127136   Click image for larger version
ID:	127137   Click image for larger version
ID:	127138   Click image for larger version
thx,
Percy
Old 06-29-2008, 12:13 AM
gtopercy's Avatar
The 69 Pro Street GTO was traded away today to a guy a South Carolina.
thanks all !!!
thx,
Percy
