Old 04-11-2008, 01:38 PM
Rico Rico is offline
Default new rides compression check
As a precaution I had a compression check done; 389 tri 4sp
results as follow:
#1 200
#2 200
#3 185
#4 210
#5 190
#6 200
#7 187
#8 190
I had a comment that it was a little high?
I'm am a novice at this stuff.
What type of gas should I be running?
Thanks,
Ric
Old 04-11-2008, 08:45 PM
Schurkey Schurkey is offline
If we assume that the compression gauge was accurate--you're into PREMIUM fuel territory there. But then, it's a 389 Tri-power. You knew that already.
In general, 150--170 is more common; but it all depends on the mechanical compression ratio and the cam timing.
