Old 04-12-2008, 04:08 AM
jmdotter jmdotter is offline
Talking Pontiac V8 in a post-'81 GMC/Chevy
I was thinking of getting a '73-79 GMC and possibly putting a Pontiac 350 in it (I always wanted a Pontiac truck). GMC's were built with the Pontiac engine, so I think it would be appropriate to continue that heritage (rationalization, maybe). Problem is, the '73-79s don't seem to be for sale very often around here in other then POS condition (do to the Northeast salt and winter fun I imagine). Brings me to my question:
Has anyone put a Pontiac V8 into a post-Pontiac engine era ('81) GMC/Chevy truck, and gotten away with it legally (emissions and all))? In the great state of New Jersey? Or even California ('cause if you can do it there, I'm golden )...
Some guy offered to trade me his '87 truck in mint shape for my '50 Ford, and I was wondering if it would be a legal swap. Whether or not I could legally do the swap (305 TPI to Poncho 350) will probably decide the outcome, so any input is welcome.
Thanks!
Old 04-12-2008, 11:11 AM
Mr6x Mr6x is offline
I would think the later trucks with the diesel 350 would make the best candidates. I think the transmission is BOP style and the frame mounts on the truck might be able to be retained. Not sure about what Pontiac motor mounts to use.
Old 04-12-2008, 08:27 PM
I think you're right Mr6x, however, I'm more concerned with the legality of the swap; most state laws require you put a same year or newer engine in your vehicle. What I'm thinking of doing is taking a engine last made in '81 and putting it in a later truck, like an '87. I'm more concerned with getting away with it then appeasing the tree huggers, so anybody with experience in doing this in New Jersey feel free to chime in... any tips/tricks to make it look legit?
1970 Pontiac LeMans Wagon - Mint Turquoise & Black, 350/TH350
Old 04-12-2008, 10:44 PM
RandyW's Avatar
RandyW RandyW is offline
Most inspectors wouldn't know the difference if you don't use Pontiac logo stuff.
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold)
Old 04-13-2008, 10:50 AM
Donovan Donovan is offline
aren't the old Diesels exempt making that kind of truck perfoect for this swap? I thought I had heard that.
Old 04-13-2008, 08:23 PM
Judge Smails's Avatar
Judge Smails Judge Smails is offline
I may be clueless but I didn't think GM had put Pontiac engines into GMCs since the mid to late '50s?
Old 04-13-2008, 09:46 PM
True. However, in my mind, GMC's should have continued to use the Pontiac engine, and never have gone to Chevy. Nothing against Chevy, just my opinion that it would have made the GMC line that much more unique and different from the Chevy line-up, and we would have had a fine substitute for a Pontiac truck.
Imagine ordering a GMC step side with a factory 455 to pull your strictly drag car around...
Old 04-14-2008, 06:25 PM
Well, I think I've figure out that I can probably get away with it. My mechanic does inspections, and he's a big GM guy. He passed my wagon with the thing leaking exhaust at the block due to snapped exhaust studs, so my guess is I could pull it off. I guess the next thing to research is, can a TBI 305 fuel injection system be mounted and made to work (well) on a small displacement Pontiac.
Old 04-14-2008, 10:22 PM
RandyW's Avatar
It'll work fine on any Pontiac.
Check this link; http://www.affordable-fuel-injection...re.php?crn=210
Old 04-14-2008, 11:50 PM
Thanks!!! I really appreciate that; looks like some cool stuff available. Ahh, the reading begins!
Old 05-08-2008, 01:50 PM
Stuckinda60s Stuckinda60s is offline
I ran a torque-built 400 in an '81 GMC Shortbed with 2.73 gears and a 3-speed. It originally had a 250-6 in it. Even with oversized tires which brought the rear ratio down to around 2.35, it still hauled a 6000# trailer/car load with ease. At speed I could pull all the hills on the interstates in NE PA in high gear. Absolutely unbelievable torque. The mileage was decent, also, running from 11-1/2 to 12-1/2 towing and 19-20, unladen. I even managed to keep the same clutch for 75k miles.
I eventually went to a 3.08 and that brought it back to about an actual 2.70 ratio.
In my opinion, when all things like mileage, reliability and towing ability are considered, the 400 makes just about the best possible towing engine.
I'm currently considering a P350 with slightly lower gears, probably a true 3.08 ratio. Then using an OD automatic. I think this would give really good mileage and still have good towing ability with the advantage of the torque converter.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 05-08-2008, 01:54 PM
By the way, most states consider vehicles older than 25-years old to be antiques and most are considered exempt from emissions testing.
Rich
Henry Ward Beecher
Old 10-06-2008, 09:40 AM
ruf455 ruf455 is offline
I am going to hijack this a bit, what frame mounts/motor mounts did you guys use? I have a 455 ready to go into my Blazer...
Old 10-06-2008, 12:40 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
I used the frame/motor mounts from a 73-77 Lemans or Grand Prix in two trucks of mine that are Poncho powered. Also I think the full size Pontiacs started used the same style around 72-73.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 10-07-2008, 03:33 PM
gto1025 gto1025 is offline
Back in the 70's I installed many 400, 455 pontiacs ond olds 455's in chevy trucks for poeple who wanted to tow. The olds 455 always felt better although I am a pontiac nut. I have a pontiac powered El Camino with a pontiac 400 w/ 4 speed and a shaker hood and trans am extracters on the front fenders, and a 75 grand am dash. I always used the mounts and rad from the doner car, usually a 69 to 73 fullsize car. I would redo the 400 trans with 4x4 tailshaft for 4x4 trucks. The 65 olds, buick and caddy 400 trans had a twin pitch converter and this worked like an overdrive. [email protected] Clarence
Clarence
1964 GTO Hardtop - Marimba Red Tripower/4speed, A/C, Tilt, Map/Dome Light, Wood Wheel, 3.08 posi, Disc brakes, f+r swaybars, frame off resto in 1984. 370,000 miles from 1984 - 2007
RIP 8/9/2007...
Old 10-07-2008, 05:59 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
Emissions shouldn't be a problem and I don't see any reason for them to pop the hood anyway.
My good friend's dad is trying to get rid of a '74 C20 Chevy long bed with a 454 auto for next to nothing if you'd be interested. I'd take it but I have no use and no room for it.
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 10-07-2008, 09:01 PM
78savette's Avatar
78savette 78savette is offline
Here's a Chev. truck with a Pont 400 in it 4 sale on my boat site.
http://forums.screamandfly.com/forum...d.php?t=168428
