I have a couple of paint code questions
What color white works best on the shaker to match the repop stripes? Also what is the correct silver/grey color for the grilles? Both are on a 71. Thanks
The stripe was unchanged from 70-72. That means that the proper shaker white is 70 code 10
Thanks, norwood.
Actually, er, no, the white stripe was not the same from 70-72. If you look at the MPC the stripe is called out under one set of part numbers for 70 and another set for 71-72. I assume that they were changed to match Polar White or Cameo White shaker respectively. Although I have never had a chance to compare the two side-by-side.
Giles,I seem to recall on SEVERAL occasions you advised me that the MPC's were NOT considered to be an "accurate" reference source/guide regarding the ACTUAL build characteristics of these cars. (with 1970 typically being the "gray" area) Perhaps the assembly manuals for each year (70-71) would reveal more accurate information regarding the stripe that was actually used in production? The Master Parts Catalogs would list replacement parts available(at the dealer level) & NOT neccessarily what was used on the cars when they were built,as I understand it.(if I am interpreting your previous comments on MPC's correctly?) |
I knew that this would start a debate. But even if the stripe white color for the blue car changed ( I have doubts). The question is "What color white works best on the shaker to match the repop stripes?". Maybe I answered the question wrong, but I assure you that code 10 matches the PG stripe perfectly. By the way DON'T USE THE PG STRIPE....
Back in the late 70's I ordered replacment stripes for my car. They all came as expected white with a solid black border. Except the roof stripe, the roof came with the black having a matrix type dot pattern. I had to order three stripe before a solid one arrived. I would have never believed this but it happened to me, so I know it to be fact. Anybody else ever seen this type of stripe? |
I have a original paint blue car that has the matrix stripe. It was built at the end of march. I personally think the matrix stripe is ugly and prefer the solid one. The shaker is the same color white.
Glad to see I could get things stirred up again...lol Anybody know what color for the grilles?
I agree 100% |
thanks guys!.....lmao
As far as getting the right color white for the stripes. I'd buy the stripes first (had good luck with S&S on my car), apply them, and then take one of the pieces (rear spoiler is a good one) into a good automotive paint store and have them match it with the electronic eye. This process worked well for me. BTW, anybody got the paint code for the green on the grilles? Mine have faded to a dull silver and I'd like to get them redone...
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
Keith, That is BRILLIANT....... I will take one of my ORIGINAL grills down to my paint guy and have him mix up a qt. for you . Craig
I checked the assembly manual and I found the white stripes are different between 70 and 71 while the blue stripes are the same: 70 White stripe - 481969 70 Blue stripe - 481970 71 White stripe - 488712 71 Blue stripe - 481970 I assume there is a slight difference in the shade of white to correspond to paint code 10 or 11 on the shaker, but have never seen the two side by side. My car has NOS stripes. I will have to dig out the receipt to see which model year they are. I have no idea! |
Another 1970 QUIRK!
Gotta love that one year ONLY stuff. |
http://cgi.ebay.com/ebaymotors/1970-...m250248255250&
Keith, I think that you are right about that stripe. I sure am glad that GM came to thier sences on that one. That looks like SH**............
