Old 04-15-2008, 10:26 AM
Eighttime's Avatar
Eighttime Eighttime is offline
Default Tempest/Lemans rear spring insulators?
My buddy asked me to talk to you guys about where to find the rear spring insulators for his Lemans. He recently replaced the springs and he said the original rubber at the top of the springs were shot. Are these reproduced? How about some made of polyurethane? Thanks.
P.S. I know both of these cars interchanged springs with other models, maybe they used the same parts.
"Trust me friend, a hundred years goes faster than you think." -Kenny Chesney
"Go fast, turn left, hang on, go straight, go faster...who wouldn't wanna piss off 900 angry horses?"
1967 Pontiac Firebird 400 Coupe
1966 Chevrolet Corvair Monza 110 Convertible
1965 Oldsmobile F85 Cutlass 350 HO Coupe, soon to have Olds 403
1970 Chevrolet Nova 383 Coupe, NEW!
2007 GMC Sierra 5.3 Z71 Ext.
2007 GMC Yukon 5.3 SLT
Old 04-15-2008, 12:58 PM
fdowdy fdowdy is offline
Default Insulators
I got mine fron Year One.
Hmmm.. Now WHERE did this part go???
Old 04-15-2008, 07:33 PM
Eighttime's Avatar
I try not to buy from them, overpriced and shipping is pricey! Anyone else?
Old 04-15-2008, 08:45 PM
GonzoF1 GonzoF1 is offline
Sure... Performance Years part number RPU186 or RPU190 depending on the year it is. Either $6 or $16 per pair. Check it out. (BTW... I had to trim a little off the end of mine. Maybe an inch or two)
Old 04-16-2008, 06:31 AM
70 Lemans's Avatar
70 Lemans 70 Lemans is offline
Default Got mine from PST
http://www.p-s-t.com/c-24-coil-sprin...ring-pads.aspx
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/[email protected] 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft.
Old 04-17-2008, 02:59 PM
Pontirag Pontirag is offline
also 73 and later rear spring insulators can be fitted to the bottom of the spring for an even quieter ride.
