Old 04-22-2008, 01:12 AM
superblue72 superblue72 is offline
Default Need help for v8 swap
I plan on swapping in a v8 over the I6 for my 72' Ventura. Here's the problem, I want to use the TH400 transmission but I don't know which size tailshaft would fit the driveshaft of the ventura. For all of you who have done v8 conversions to a 71-72 x-body, help me out please.
Here's a list of what they in terms of tailshaft size
http://www.tciauto.com/Products/GM/g...amatic_400.asp
Old 04-22-2008, 06:42 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Should be 4 tailshaft with large yoke
Old 04-22-2008, 07:43 AM
Rob B's Avatar
Rob B Rob B is offline
4" tailshaft then your best bet is to buy a T400 crossmember for a 67-69 firebird (camaro) from PY as well as a OEM dipstick tube no a silly chrome universal. You could also opt for the Locar flex tube.
You should only have to change out the yoke on your driveshaft from the T350 one (smaller) to the larger T400.
It's a simple conversion all and all, just need to do a little planning first.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 04-22-2008, 12:15 PM
hey thanks
anyway i plan on putting a buick 455 in it. another thing i'm concerned about is the electrical. any tips on that?
Old 04-22-2008, 01:45 PM
Rob B's Avatar
Originally Posted by superblue72
hey thanks
Can't be to hard, not much to the electrical system on these cars. Worse case is you have to flip the wiring harness to the other side of the engine compartment.
Old 04-22-2008, 10:26 PM
nonnova's Avatar
nonnova nonnova is offline
Location: Cleverly Disguised As A Responsible Adult In The Motor City
You may have to re-route or run new fuel lines also depending on which side the fuel pump is on. I had to do this when I swapped out the Olds 350 for the Pontiac 400 in my Omega.
What exhaust manifolds/headers are you planning on using? Something else to consider when putting a Buick 455 in. No Buick motored car has the "rear steer" other than the Apollo which came with a Buick 350 so you may have clearance problems with stock 455 manifolds or headers for a 455 car
1974 Oldsmobile Omega: '73 Pontiac YX code 400, 4X-7H Heads, Edelbrock cam/intake,
Holley 750 dbl pumper, Dynomax headers, 2.5" 50 series Flowmasters, M20 Muncie 4spd,
8.5" 10 bolt with Auburn race series posi, 3:73 gears and 4 wheel disc brakes
Looking for the right Ventura for the drivetrain ('73 w/o Sprint nose)
Old 04-24-2008, 12:19 AM
thanks a bunch
all of the info was really helpful. i'm looking at a 455 buick engine but my mind hasn't yet set on which engine i want to use. what are some other engines with high horsepower(stock) out there?
