New build
I'm building a 71 firebird.Mostly race but some street.IA II,4.5 stroke crank 6.7 BME rods ,HP heads by Jim Robertson 400+,Victor intake,1250 carb.10 inch tire.No dyno yet but hopefully a lot of power.3500 lbs or so.What transmission would be best.
TH400
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
Lotta horsepower & torque on a heavy car with a small rear tire,a well built 2.10 low TH-400 would hafta be my choice.
Dream tranny...
T- 400 with a gear venders behind it, Cake and eat it too. I have one behind my muncie in my 66 and love it. Think they can go 1200 hp with a tweak on the pressure... Will put one on the 63 if it ever sees much street. Seen some heavy cars out at Formosa useing one as a gear splitter. Kool stuff. John Krull
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
The Bandit Rules - Make mine with a SD-455 Engine . |
Be nice to get it done.Long way to go.
Not sure what area you are in but check with Paul Starnes --Starnes Automatics goes by TTS here on the boards. We are running one in my GTO that is in the 700HP range and one in my BIL's 70 Chevelle that is in the 950hp range N/A and they perform flawlessly. He shipped us 2 from TX to GA. I kept the old one he built 4 years ago as a spare- had about 200 N/A passes on it and about 30 N20 passes. You won't be dissappointed. http://www.starnesperformance.com/
Whoo-hoo! I gotta get busy!~ BTW it's Starnes Performance Automatics
Tough to go wrong with a 400. At your HP level, there really isn't a choice unless you want to race heads up. Then it's REAL BIG $$$$.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson "If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams Right and wrong doesn't need facts all the time. -Lighthouseman ("lawyer") Starnes Performance Automatics www.Starnesperformance.com |
I built a balls out TH400 for a Pontiac a few years ago. I'm still waiting for it to return... I don't think it will, but there's still a chance . If anyone's in Northern Indiana with a bolt cutter.....
The transmissions in Mike and Ken's are stockers. I wanted to see just how far they can go with stock hard parts, and they're nice enough guys to try . Honestly , I couldn't afford for someone else to disappear with major hardware, so this honest duo has given me a chance to get in some real R&D. So, Mike Davis and Ken Weilbrenner thank you very much!
I've talked to a couple of people that think a powerglide would be a good choice.But I think I like the 3 gears with a turbo 400.Could I just run a higher rear gear to tone down the launch?I worry about turbo 400's because I see someone like Mighty TA tearing his up frequently.I sent a PM to someone on the board who was selling a 2.10 low turbo 400 but he said he was going to put it back in his car.That may have been a good transmission for my build.TTS I'll call you tomorrow.I'm up in Greenville SC Mike.
