Old 05-10-2008, 09:14 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Default Looking for 6.2 & 6.5 info
Does anyone know 6.2 or 6.5 diesels on here ?
Not my favorite diesel, but Im told some 6.2 and 6.5s had steel cranks ?
If so can you ID them in the engine by the flange ?
Im needing a lightweight diesel , and a inliner wont fit without alot of modifications.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 05-11-2008, 02:57 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I don't know those engines well enough to answer your question, but www.thedieselpage.com is the expert site on those engines. LOT of archived info there to dig through.
'Course, if you REALLY want lightweight, it's hard to beat a Duramax with those aluminum heads.
Mike
Old 05-11-2008, 09:30 PM
Duramaxx would tear up the driveline with its torque.
And yes Mike, I drove a Duramaxx recently and was impressed with its power.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-12-2008, 12:18 AM
the "black engines were the better ones. if irc they came out in late 83. i've got one in my 78 4x4 it's turned up to the ragged edge of smoking bad, has decent power, runs well and pulls over 3mpg with a straight 4spd,4:10's and 33" tires in a 6k# truck.
mike
former." --Albert Einstein
- Winston Churchill
Old 05-13-2008, 07:54 AM
mzbk2l's Avatar
I was just yanking your chain with the duramax comment.
I really would check out the diesel page, though... there are probably hundreds of members there who could answer any question you might have on the 6.2/6.5 right off the top of their heads.
Mike
Old 05-13-2008, 12:15 PM
I know.I'll never hear the end of that. I have heard of some Duramaxx issues; there is a coating they used on the heads to prevent corrosion and some owners neglected to change the coolant when they were supposed to. It would eat through the coating, but thats on the owners, not the engine. 6.9s and 7.3s can calvitate in the rear cylinders by the same neglect -
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-13-2008, 12:20 PM
mike
Thanks for the info, Mike -
Im dropping one in a old Land Rover pickup; it has a underpowered 62 hp 4 cylinder diesel and they make conversion kits for the 6.2.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-13-2008, 02:48 PM
you'll like the 6.2 in that l/r, jsut gear it to take advantage of the torque band. i know of several blazers that pull 25mpg on a regular basis. the mechanical pump 62/5's are a good engine they just aren't the powerhouses the newer ones are.
mike
- Winston Churchill
Old 05-13-2008, 02:58 PM
mike
Mike, Ive always heard the 6.2s forte was 20 + mpg. 62 hp to 135 + hp will be night/day, though. I laugh everytime I hear a newer diesel owner (Duramaxx, Cummins, Powerstroke) tell me they get 30 mpg
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-13-2008, 04:43 PM
sleepy's Avatar
sleepy sleepy is offline
A friend of mine has a 06 duramax and he is lucky to get 12. my 82 6.2 got 28 hwy and 25 city. I wish I still had that truck.
Old 05-13-2008, 05:31 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
I had a 6.2 in a heavy 3/4 ton no OD trans and still pulled over 20 mpg and it didn't matter if it was fully loaded down and that was with 225000+ miles on it.
www.pro-touringf-body.com
Old 05-13-2008, 08:28 PM
They have 'em turned up so high (365 hp) from the factory these days. If you buy a Duramaxx in some motorhome chassis I think its 230 hp or something like that.
I read GM had an economy 6.2 in step vans that was less hp for fuel economy
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-14-2008, 07:16 AM
Cliff R's Avatar
Cliff R Cliff R is offline
All of the 6.2's I've been into had iron cranks. The turbo charged 6.5.s are supposed to have steel cranks, but I'm not sure?
The 6.2's come in several "flavors", very early units have different rocker arm set-ups, water pump, etc.
None of those engines are overly impressive, in any configuration, and every single one I've had apart had major cracks in the pre-combustion chambers, and some across the exhaust valve seats.
Those engines are NOT direct injected, or did they have intercoolers on the later turbo charged versions, they are basically considered TURDS in the diesel world, at least compared to other designs. Some folks have still spent the time/funds to get some pretty impressive power from them, so they do have some potential.
The later Duramax engines, at least those I've driven, are much better, but seem to be pretty thirsty. We took a friends 2005 Duramax to Daytona last year for bike week, pulling a small trailer with 2 bikes in it, and it never did hit 10 miles to the gallon! It's pretty much "stock" except for some sort of "chip" in it......Cliff
Old 05-14-2008, 12:19 PM
The iron cranks are bad about breaking around the 2nd main cap.
If I can find a 3.9 Cummins BT I'll go that route -
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-14-2008, 04:03 PM
as long as the 6.2's not turned up until it smokes like a coal burner it's efficiency increases with turning up the fuel as long as the advance cam is adjusted also. you don't want to get crazy with the advance but a little goes a long way.
the step van version was severely underpowered.
i've seen a total of 2 cranks broken in a 6.2 that were n/a. the banks kit really wakes them up but it'll also spit the crank out of the block in short order if the engine's run hard.
i've seen more cracks in the main webbing of the block and gaulding of number 8 cyl than i've seen other issues.
i'd be on the hunt for a ton truck as a donor. the non emission version, no egr, will be the snappiest of the bunch.
as i said above, they're not a duramax but iwth some care they're a good engine for a driver. i've actually thought about stuffing one in a mid 70's pontiac for a driver.
mike
- Winston Churchill
Old 05-14-2008, 04:50 PM
Mike, If I drop a 6.2 in I have a complete set of the red headed stepchildren of diesels : Olds 5.7 and IH DV-550, though both run real well and earn their keep.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-14-2008, 07:49 PM
the 5.7 must be a later model. i've seen those run a LOT of miles. in fact i know of one right now that runs well in a mid 80's park ave.
that binder engine kind of scares me, i've not heard a lot of good about them. i like the dt466 and dt366 for an international engine.
mike
- Winston Churchill
Old 05-14-2008, 10:43 PM
mike
Despite low miles it has a later "WX" replacement block (deeper holes tapped for main bolts) I bought it with a bad headgasket: Ended up removing the block and installing ARP studs. Im averaging 30 mpg running the A/C.
I have a later 9.0 which was a somewhat improved DV550. 550s & 9.0s are gutless : about 180 hp and they are L-O-U-D when climbing a hill loaded. The DT466 is probably the best medium duty diesel ever made.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-15-2008, 05:10 PM
that's my opinom on the dt series of engines also. the 366 can be made to run well but it takes a little tweaking. i've got it in my head that i'd like to stuff one in a vintage binder pickup or shorten my co1600 down, stick one in there and use it to pull trailers.
i know a guy who's in the process of changing a 9.0 in a payloader. he's not having any fun with it and is hoping the one he bought is a good one.
mike
- Winston Churchill
Old 05-15-2008, 10:35 PM
They made several displacements for the 466 series: DT360, DT408, DT466, DT530 and now DT570. I think DT stood for "Diesel Turbo"
It started out as a farm tractor engine in 414 cid in the 1960's.
The 9.0 has some good points: easy to start when cold, and suprisingly decent fuel economy. If your friend sells that extra 9.0 tell him they are in high demand with the tractor pulling crowd.
'79 455 Trans Am
‘23 Lexus LS500 awd
