I'm looking to rebuild my front end on my 67 Catalina 2+2. I've got the shocks, springs, all four ball joints, inner tie rod ends, stabilizer links, and all bushings. Is this sufficient for a decent rebuild? Or should I also include new center link, inner tie rod ends, idler arms, etc. The steering on the car is quite a bit loose, feels like I'm driving a boat. I guess my question is what's the most important parts to replace for a decent job. Thanks.
Definately the idler arm and outer tie rod ends. I then think that you have covered the bases.....
Oops, I have the outer tie rod ends, not the inner. Thanks for your input.
Just do it all.
Sammy 1967 Lemans: 455 swap in progress (stock crank, stock rods, TRW slugs, mildly ported 6x heads, Stump Puller hyd roller, 1.5 PRW aluminum rollers, Comp hyd roller lifters, Performer RPM, q-jet, RA exhaust manifolds, 2 1/2" exhaust, ebay HEI), 200 4R, and some suspension stuff |
Yeah, I guess that's the best thing. Thanks
