Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 05-20-2008, 10:34 AM
ReelFun's Avatar
ReelFun ReelFun is offline
Default M & H ELECTRICS
I bought a new engine and a dash harness from M & H. I had them modify it for internally regulated distrubutor and HEI ignition. Finally installed them this past weekend. All went well with no problems. The new harness even solved some other electrical issues I had due to someone hacking into the old harness at some point. The harness' were exactly as original except for the mentioned modifications. I highly recommend them. :thumbup:
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 05-20-2008, 01:44 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
I also have bought new harnesses from M&H. While not ready to install them just yet I love that they are exactly like my original harnesses.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 05-20-2008, 01:49 PM
Wakepowell Wakepowell is offline
I'll post another thumbs up for M&H Fabricators. I bought a rare rear harness with the fiber optic tail lamp monitor system and it was identical to the original.
Old 05-20-2008, 03:04 PM
GT182's Avatar
GT182 GT182 is offline
I've only bought a wiper switch from M&H and haven't had any problems. It's a great quality item. I feel they're a good company to order from. If I have to get a harness it'll be from them. :D
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 05-20-2008, 03:44 PM
1969 Ram Air 1969 Ram Air is offline
M&H is an excellent company. I've bought several wiring harnesses from them.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 05-20-2008, 06:12 PM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
I've also bought all my harnesses from them. Last purchase they made me a custom length starter cable for my '64. made one exactly like the original but a bit longer, so I can run my HO exh. manifolds (and route the cable out the front). Have not had a problem yet!
Old 05-20-2008, 09:15 PM
stevep's Avatar
stevep stevep is offline
I have bought a few harnesses from them with no issues.
Old 05-21-2008, 01:07 AM
pont406's Avatar
pont406 pont406 is offline
great to deal with! I have their engine and dash harness in my 66 Lemans, had it modded for the 1 wire alternator, and HEI, everything fits great and all the wires were long enough to get where they needed to be!
Old 05-21-2008, 04:33 PM
bigunde bigunde is offline
How long does it take to get one once ordered? I need a engine harness for my 79 T/A and Performance Years and Ames has a 6-8 week wait.
Old 05-21-2008, 08:54 PM
nashcar nashcar is offline
Another thumbs-up here.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 05-21-2008, 10:44 PM
ReelFun's Avatar
Bigunde, it should take about a week or less.
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 05-22-2008, 12:04 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I used a front and rear M&H harness for my 64. nice stuff. :burnout:
64 Lemans hardtop
4spd, buckets
Old 05-22-2008, 12:55 AM
pont406's Avatar
Get ahold of them Direct, you may be able to get your stuff quicker!
Old 05-22-2008, 09:26 AM
GT182's Avatar
Bigundie, here the numbers at M&H....
Sales and Customer Service
(562) 926-9552
Technical Support
(562) 926-9562
24 Hour Fax Line
(562) 926-9572
and web link.... http://www.wiringharness.com/
Gary
Old 05-22-2008, 11:22 AM
(562) 926-9552
Technical Support
(562) 926-9562
24 Hour Fax Line
(562) 926-9572
Thanks,got mine ordered.They say 3-4 weeks.
Old 05-22-2008, 12:35 PM
GT182's Avatar
3 to 4 weeks isn't too bad. Anyways, I don't think you'll be disappointed with their quaility.
Gary
Old 05-22-2008, 08:47 PM
sixxty7's Avatar
sixxty7 sixxty7 is offline
thumbs up here. excellent customer service. bought a standard engine harness from them. months later they upgraded it to a ram air harness. even told me what length batttery cables i would need for the conversion. also have their point conversion kit on my distributor, works like a charm.
Old 07-09-2008, 02:05 PM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
I've bought from them plenty of times, they're right down the street from me, never had ANY problems with ANYTHING I've purchased from them...
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
Old 07-09-2008, 07:02 PM
JLHarper's Avatar
JLHarper JLHarper is offline
My 70 GTO underhood harness was out of stock but worth the wait. Looks top notch.
They have other parts also, coils, battery cables and more listed as OEM correct.
The tech guys knew their part #, and applications too. Called me back to see if needed AC harness as example. Called me later for ship update as well.
Old 07-09-2008, 10:58 PM
They sell OEM battery cables? Are you serious? I did not know that...and that's good to know!!!
Smilies are Off
