Any advise when replacing exhaust manifold gaskets on a 1968 400 non-R/A non-H/O?
It seems there are only 4 bolts holding on the manifold. Do four bolts create enough of a seal? Are paper/cork gaskets better than metal? Thanks for any input |
My advice- Don't use the steel or the paper. Get a set of the good composite gaskets from Fel-Pro or Mr. Gasket. I've never had any leaks using them. They have a steel core and a material on both sides that compress' to seal up minor imperfctions.
Last time a did a set of exhaust gaskets I used the original style steel gaskets based on someone's advice and they leaked right from the get-go.
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
If the manifold surfaces are "flat", the shims are the way to go. Have the manifolds resurfaced if they're not flat (within .003"). The 4-bolt retention seemed to work well in stock engines. The factory used NO gaskets.
Jim |
Agree that the manifold surfaces must be absolutely flat and level or resurfaced to achieve same. Over time the center cylinder manifold tubes warp outward from the heat. I used a set of thin steel gaskets as (I was told) they would dissipate heat.
resurface to make sure you are not warped this is common
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
Thanks for answers. I'm not going to resurface, I think I'll go with the Mr. Gasket type as suggested. I have 108,000 original miles.
Does anyone think the bolts will snap based on experience. I did the right side and the bolts came out fine. |
On my 68 Lemans I have 6 bolts per side.
if you are going to replace the bolts make sure they are grade 8 because after they heat cycle a bunch of times and rust over the years you will still be able to get them out - the cheap grade 5 or three can rust over time and when you go to take them out break off then the fun begins.
anti seize on new bolts and proper torque.
