It was pointed out the dash pad & top painted finish was too flat on our 69 TA. What would be the correct percentage of flatness? Is the dash metal top between the winshield & dash pad the same sheen as the dash front?
One of the Lucky 697 |
The top of the dash should be suede textured 0 deg gloss.
The suede is an additive...
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict 68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars) 70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI |
You RULE. Thanks for the quick reply!! We'll correct the front & leave the top as-is.
Suede?? I always wondered how that texture was achieved, learn something new everyday.
I reproduced the correct texture for the dash top by using cans of semi-gloss and spraying from two feet above (dry spraying??) and letting the mist settle on the dash a little at a time letting it dry for a few minutes in between coats. It gave me a nice matte non-reflective finish like orig. If you spray one spot too much it will go glossy and you'll have to let dry and start misting it again.
1967 Firebird 326 H.O. Conv., M3 floor shift, 3.36:1, Montreaux Blue/Parchment, Dual factory traction bars 2005 IBM GTO M6 - One of 347 1984 Yamaha FJ1100 |
