Old 06-05-2008, 03:44 PM
Pontiacventura73 Pontiacventura73 is offline
Default Putting a 454 BBC in 73 ventura
Please help.... I am putting a 454 Chevy motor in my 73 Ventura and need some help.
If anyone has done this I need to know what motor mounts to use and the oil pan is
hitting the steering link that is behind the frame cross over. Help....
Old 06-05-2008, 04:33 PM
lc2 tech lc2 tech is offline
use 69 camaro/nova bbc motor mounts
1974 ventura/apollo/GTO mix ) Sold
1992 B4C Camaro -Sold
1987 Buick grand national - Sold
1992 Typhoon- Sold
1989 Turbo Trans Am #1267
Old 06-05-2008, 04:45 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Don't do it, aaaahhhh!
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 06-06-2008, 12:26 AM
Thank you Lc2 Tech... Do you have any suggestions on the oil pan. the 454 came out of a 73 vette and the oil pan will not clear the steering linkage.
Old 06-06-2008, 11:18 AM
Rob B's Avatar
Rob B Rob B is offline
You'll probably need to change pans.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 06-06-2008, 03:31 PM
nonnova's Avatar
nonnova nonnova is offline
Location: Cleverly Disguised As A Responsible Adult In The Motor City
Since the 67-69 Camaro and 68-74 Nova used the same subframe as your 73 Ventura, I would think You would need an oil pan from a big block for one of those cars to clear the "rear steer".
1974 Oldsmobile Omega: '73 Pontiac YX code 400, 4X-7H Heads, Edelbrock cam/intake,
Holley 750 dbl pumper, Dynomax headers, 2.5" 50 series Flowmasters, M20 Muncie 4spd,
8.5" 10 bolt with Auburn race series posi, 3:73 gears and 4 wheel disc brakes
Looking for the right Ventura for the drivetrain ('73 w/o Sprint nose)
Old 06-07-2008, 02:59 AM
goquick's Avatar
goquick goquick is offline
Use the nova/ 67-69 camero pan. But as always, why are you wasting a Ventura on a bbc? A Pontiac 455 would have been much easier, cheaper and quicker.
Old 06-07-2008, 02:35 PM
72Ventura's Avatar
72Ventura 72Ventura is offline
If he already has the 454 than that would be the easiest, cheapest and quickest.
As stated above, the frame mounts are readily available from any 1st gen Camaro or third gen Nova supplier. If you get the right mounts it might clear up your oil pan issue, or not.
The beatings will continue until morale improves!!!
Old 06-09-2008, 10:06 AM
Default BBC or 350 Pontiac
After trying to place the 454 in my Ventura this weekend, I am strongly
thinking of putting my 350 Pontiac back in. The problems I ran into was
the overall length. It looks like I would have to cut the back wall to move
the BBC back enough to fit. I tried an oil pan from a 69 Camaro and it still
hit the steering link.
So now I have a 350 Pontiac with a performace-plus Edelbrock cam. What can
I do on a budget to get some power from this? What kind of Headers fit the Ventura?
Currently I am running all Edelbrock set up.....
Old 06-09-2008, 10:26 AM
BILTIT's Avatar
Headers for the 67-69 firebird fit the ventura's.
Derek B.
Old 06-09-2008, 04:17 PM
Kyflier Kyflier is offline
Pontiacventura73.....Call me (513) 673-8997 Kenny
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 08-23-2008, 08:33 AM
Wareagle's Avatar
Wareagle Wareagle is offline
A local fellow put a 396 into his 74 GTO years ago here--bent the frame . Ruined
the car -- finally junked it--don't do it .
Old 08-23-2008, 11:45 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
the big block will go right in, not that it would be my choice,but go ahead. you must be using the wrong parts. i have seen novas with big blocks and they have no problems. ventura and nova are basically the same body. get the parts to put the motor in a nova and you should have no problem. chenk your local car shows for somebody with a nova and see how tight it is.
Old 08-23-2008, 09:31 PM
ponjohn's Avatar
ponjohn ponjohn is offline
My car had a 605 Donovan in it with the prev owner. No hammers needed, goes right in.
Old 08-25-2008, 03:01 PM
sleepy's Avatar
sleepy sleepy is offline
So what are you gettting at? The pontiac frame can't handle a BBC?
Old 08-25-2008, 04:04 PM
I ended up putting the original 350 Pontiac back in the car. I ran into a number of problems like oil pan hitting the steering link and maybe if I had that right it
would have fit better, but I didnt think I had the room for the 454. I have decided to sale the BBC and buy a 400 or 455 Pontiac...... Thanks for all the help...
Old 08-26-2008, 02:19 PM
Overkillphil's Avatar
...another happy ending...
Old 08-26-2008, 11:09 PM
Fake Goat's Avatar
Fake Goat Fake Goat is offline
Yeah, everybody knows the Nova subframes are much tougher than the Venturas. Geez, don't be so defensive. If everyone was being honest, the 454 would probably have been easier to get more HP and less expensive. Stoneburg speaks the truth, you can't swing a dead cat without hitting a BBC Nova.
If you pick up a starving dog and make him prosperous, he will not bite you; that is the principal difference between a dog and a man.
Mark Twain
Old 08-27-2008, 05:17 AM
Stuckinda60s Stuckinda60s is offline
Check out the 326/350 thread in the street section for some mods done to 350's to get some pretty decent street hp levels. Some of the guys are deep into the 13's. 400 hp isn't too hard to get.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 08-27-2008, 10:19 AM
to be honest, i dont think that it's easier to get 400-500 hp from a chevy than a pontiac. as a matter of fact i think its fairly easy to get 500-550 hp from a pontiac and you get tons of torque to go along with it. i've been doin' it for years.even using ported D-ports. no round port or aluminum head. at that level the stock block,crank,and even rods hold up with no problems. really the chevy camps only shining point is at all out max effort and at that point you're are using all aftermarket parts
