Old 06-25-2008, 02:06 PM
PONTIAC DUDE's Avatar
Thumbs up Waddaya think for a sticky. Race section. Your ride with ET & mph.
Would be nice to list in order what you car runs under each second ET group.
I know it would be a lot of work for a mod to get PM's and sort as a sticky, but................
List your best ET/MPH....60 ft'er.......... Your Name.... type vehicle.... engine size.... tire.... weight.... NA or power adder.
then do it for each second IE 6's, 7's, 8's etc, all the way to 15's.
It would be a trust deal.
Waddaya think?
Old 06-25-2008, 02:10 PM
WARPed's Avatar
WARPed WARPed is offline
Yea, something like this:
Your track times
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 06-25-2008, 02:26 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
If it would eliminate all the BS posts from the "I have the fastest car and my engine that somebody else built made the most HP" people from the all over the board and putting that kind of stuff in one place I'd say hell ya.......
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 06-25-2008, 02:30 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Sounds good to me.
Im on another site where they have special avatars you get for whatever your car runs.
They have 8,9,10,etc avatars.
You show a timeslip and become a (8,9,etc) club member that shows up in your avatar space!
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 06-25-2008, 03:28 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Sounds cool even though im only in the 11 sec. club.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 06-25-2008, 06:58 PM
GTOLIB GTOLIB is offline
sounds good , do you mean that they could they be updated by the mods?
Old 06-25-2008, 08:52 PM
flamedabone flamedabone is offline
I used to have mine in my signature, but the et is just too dammn embarassing. The mph is killer, but the 60' and the et are just too shamefull to be made public.
So, if I posted my #s, do I have to fess up to everything, or just the killer mph????????
-Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5
1933, 1934, 1936 and 1940 Fords, also Pontiac powered.
Old 06-25-2008, 09:03 PM
Jeff V Jeff V is offline
Talking Who's that dude?
1968 Firebird
525 all aluminum IA2,built by Jerry Loan
Wide Port E-Heads by SD
Glide
4.10 rear
1.299 60FT,5.74 at 120,9.02 at 148
2980lbs with driver
1966 GTO
482
E-Heads
Turbo 400
4.10 rear
1.34 60FT,6.21 at 108,9.84 at 136
3630lbs with driver
Name:	66 gto launch.JPG
ID:	134364   Click image for larger version
Jeff Verdi
2016 Spring Fling Million Winner
2016 CARS Million Winner
Old 06-25-2008, 11:38 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
See video below....
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 06-26-2008, 12:04 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Okay! I've got to put mine in here.
1964 GTO about 2670 lb. race weight
606" IA tall deck, Super Chief heads, dual 1290 Dominators
glide, 4.29s, 32.5 X 15 Hoosiers
1.2028 60'
4.2908 @ 132.01 1/8
8.1689 @ 162.56 1/4
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 06-26-2008, 12:05 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
I'm in
1970 GTO
IA2 541 ci. 3600lbs. TH400 reverse, manual and 12bolt c/w 3.73 spool
60Ft 1.48
MPH 127.48
ET 10.605 @ 2300 ft
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 06-26-2008, 12:08 AM
WARPed's Avatar
1.2028 60'
4.2908 @ 132.01 1/8
8.1689 @ 162.56 1/4
Show off
1994 Formula
Old 06-26-2008, 12:11 AM
WDCreech's Avatar
Originally Posted by WARPed View Post
Show off
Thank You!
Bill
Old 06-26-2008, 12:19 AM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
I think that a nice "add" to the post would be to also list fuel type and street driven/legal vs. track only.
Just to give a clearer idea of what type of cars we are reading about.
Whadya think?
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 06-26-2008, 01:02 AM
440GP69's Avatar
440GP69 440GP69 is offline
good idea! may be a pain to update et's all the time?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 06-26-2008, 06:23 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Mine:
Track only.
112 fuel (12.6:1)
3150# '69 Lemans
30x9" tire
True 455 CI, NA
9.81 @ 136.xx (in sig)
1.39 60'
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 06-26-2008, 08:19 AM
Ron H's Avatar
Ron H Ron H is offline
68 firebird 2940 lbs
463 N/A
Track only
TH400 T Brake 3.89 28 x 11.5
Stock Suspension
110 octane 11.2 CR
1.39 60' 6.51 1/8th
10.24 @ 131 mph @ 5000' DA
9.79 @ 136 mph using S/ST NHRA correction factor of 9.566
68 Firebird
Are you running with the wind or breaking it?
Old 06-26-2008, 08:29 AM
Goat-Racer's Avatar
Default I like it!!!!!
'65 GTO 3850 lbs.
421(427) cid N/A
Street car w/ full interior and full exhaust (3-5k mi. per year)
200-4R OD trans (footbrake) 4.11 gear and Eaton posi
295/65-15 MT drag radials
stock susp.
91 octane pump gas and 11.4:1 cr
1.44 60'
10.59 @ 124.5
Brian Rock
Old 06-26-2008, 09:58 AM
WDCreech's Avatar
I made a misprint on the 1/4 mile et in my first post. It should read 8.2689, NOT 8.1689.
Bill
Old 06-26-2008, 11:33 AM
Talking
Yea anyway. We don't need no Ray Cox made up times. Bwahahahahahahahaha
Like his .48 that should be a .58 or even .68
