engine temperature
why would my engine temp. get hotter while on the highway?
many causes
restricted radiator thermostat stationary fan impeding air flow look in 'heating and cooling' lots of good info there
aaaargh |
on the highway, air can go anywhere. it follows the path of least restriction. where would you say your thrttle position is during cruising on the highway. Im fighting this same situation on my buddies bandit. on the highway his temp sky rockets. IM really leaning towards his primary jetting is lean. hes at partial throttle so we are NOT into the secondaries yet. try running the car PARKED & watch the temp. BE CAREFUL & get access to your rad & put your hand all over it & see if the temp is the same all over the rad & u dont have blockage. lean, incorrect timing all can make run hot. if the block is 60 over that could cause aswell.... run distillled water NOT TAP & antifreeze or try water wetter
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! Last edited by SWEETJUDGE; 06-26-2008 at 12:16 PM. Reason: misspelling |
Best cooling mod I ever did and the one that gave the most results was modifying the water pump backing plate. There is a mega post on this topic and it details what you need to do. Check all the obvious first as in the first repsonse to your post and then do this.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
You running a shroud and fan clutch? What kind of fan?
Mark, got a link?
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
maybe your lower radiator hose is partially collapsing at the higher RPMs?
Not enough timing advance in the distributor.
What he said...
glad your back in action.. hope we helped
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
Does anyone have a link to this divider plate thread, or can tell me its location so I can search for it?
Its the sticky thread right at the top of the heating and cooling section.
The cast impeller thread with about a million posts in it by now.
- Tim 68 Tempest Custom Convertible 71 Dodge W200 3/4 ton 4X4 4 speed |
Thanks!!
