Old 06-29-2008, 09:20 AM
67cruiser 67cruiser is offline
Default ok, what are you running for collant??
I hear all the time straight water, another says anti freeze slight fixture, so what is everybody running anyways?? 1967 gto getting ready to try it out, running straight water, im also being told there,s a ceramic coolant out that actually coats the inside of the block, and helps protect the block also, im all ears ,what are you running??
Old 06-29-2008, 09:31 AM
4dblnkldude's Avatar
Wow, I never gave this much thought. I'm running a 70-30 mix with regular prestone, 70% water. I was under the impression that strait water does cool the best but the reason why you put antifreeze in there was to prevent rust. Anti freeze does have a anti rust agent added to it. I'd be interested to hear what others think.
Old 06-29-2008, 09:41 AM
wytnyt's Avatar
wytnyt wytnyt is offline
using only water isnt good,,,50/50 mix raises the boiling point of your radiator
but running all antifreeze will actually allow it to freeze up in winter
aaaargh
Old 06-29-2008, 09:53 AM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
I put Water Wetter in my Firebird and dropped the operating temps 10-12 degrees, I need to dump the antifreeze in the GTO and replace it with Water Wetter, and when my 455 build is done I'll put Water Wetter in the LeMans as well...
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
Old 06-29-2008, 10:56 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
Run 50/50 water antifreeze. I should be able to get away with 60% water and 40% antifreeze. As stated antifreeze does raise the boiling point and provide a good lubricant for the water pump. Water (deionised) is best to use in your system to reduce scaling etc. A 50/50 mix give a -37* freezing point with a 223* boiling point, so by reducing the antifreeze by 10% i should still be safe for storage during the winter months and have a better efficient coolant system .
Scott
If you always do what you always did
You always get what you always got
Old 07-07-2008, 04:53 PM
cmayna's Avatar
cmayna cmayna is offline
My brother use to run 50/50 coolant/water in the 67. When I got the car I did not like the high temp while running the car at a pretty brisk rate or around town, so as I use in my old Mustangs and old Chevy truck, I replaced it with 70/30 distilled water/coolant and a bottle of water wetter.
Now the temp runs at a pretty steady 180-183. Much better.
More GTO pics Craig
Old 07-07-2008, 06:26 PM
Z Code 400 Z Code 400 is offline
70% distilled water and 30% coolant. I mix it in a container and pour it in at the correct percentage...Robert
Old 07-19-2008, 11:32 PM
ClassJ ClassJ is offline
Similar here. 70% distilled water, 30% antifreeze. I throw in a bottle or two of water wetter as well. Works great!
Old 07-21-2008, 10:13 PM
mwritter's Avatar
mwritter mwritter is offline
I do 50/50 Prestone and distilled H20, with a bottle of water wetter.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 07-22-2008, 01:20 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Distilled water for sure, and about 75/25 mix. Like mentioned, you want antifreeze to up your boiling point, water is 212, way too many GTO's hit that on this board so stay far away from straight water if you have a bunch of stock cooling parts still.
RMI 25 is the most referenced additive for cooling, helps with core build up and reduces temps better than any other. I know a few guys who had to flush the system after a month of use due to it cleaning up the core ( older core though ).
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 07-22-2008, 11:30 PM
rotdog rotdog is offline
RMI 25 Can you get that auto parts house?
Old 08-01-2008, 08:21 PM
scotzz's Avatar
scotzz scotzz is offline
what is "water wetter" and where do you get it?
Old 08-01-2008, 10:29 PM
read this . http://www.redlineoil.com/products_coolant.asp
You should be able to buy water wetter at any parts or speed shop.
Scott
Old 08-04-2008, 04:57 PM
carcollector's Avatar
carcollector carcollector is offline
Providing your coolant system is in proper working condition, 70/30 is the way to go. I run 80/20. Less junk to remove later when changing the coolant.
Use only G-05 coolant(Honda, Ford, Mercedes).
