1970 gto engine pulley paint
What paint is used on the pulleys for a 1970 GTO?
It's a semi-gloss black. I powder coated all of mine.
GoatDr |
Dont paint the grooves
why not paint the grooves...were the grooves painted originally?
I've painted the grooves on mine, never had a problem. Powder coating is best, most durable, but a semi gloss out of a can is fine. Duplicolor is great, comes out of the can real nice and is available EVERYWHERE...
I'm sorry - where you asking what color? I've painted all my pulley's semi gloss black, I like the contrast to the engine block color
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
Krylon, I forget the exact name of the black (semi-gloss black?), but it's #1613
powdercoating will add a small bit of material to the pulley groove (and rest of pulley for that matter). may be a problem, may not.
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
this should work if not krylon some kind of sation black.
I've powder-coated with Gloss Black :excellent, don't paint into the grooves.
Powder coat can go on thick, thus ruining the readability. Powder coat can show a craze texture called "orange peel" depending on who's process was used. You want the texture to be still-pond optical flatness. I've used Semi-gloss: must glass-bead, use black non-sanding primer, then paint Semi-Gloss Black for satisfaction. Flatness is nearly always a still pond optically flat. Code readability excellent. I've preferred factory paint, thus good original condition pulleys simple because the pully metal can have pits in really important inside creases that affect strength. Except GTO Alt-Pulley, I prefer the 1980s-1990s large diameter pulley having a chromate//clear coating. ================================================== ====== OHC6-Alt pulley is double-row, so Gloss Black powder-coat looked super. |
