Old 07-14-2008, 11:05 PM
Don66GTO Don66GTO is offline
Default Trying to ID a engine still in a car.
Ok. the engine code is YS.
there is a date code on the distributer pad. it is e285 (may 28 either 65 or 75?)
I did not see any casting numbers there in the distributer pad...just the date.
The machined flat tag place next to the date code was blank.
I do not know how many freeze plugs are on the motor yet. (2 means it is a 389 from 65 and 3 would make it a 400 from 75?)
I do not know how many motor mount holes there are yet.
the heads on the car are 46 heads and not factory for either of the ys engines. (65, 75).
I know that the casting number for the 389 is 9778789 but do not know where to look for it.
the casting number for the 75 400 should be either 481988 or 500557. it should be behind the number eight cylinder if I am not mistaken...I just can't see it with the motor still in the car.
anyway does anyone know what I am looking at as far as what type of motor this is?
I appreciate any help you guys can give me. Thanks!
Old 07-15-2008, 01:25 AM
The way bolt on parts interchange, what you're looking at, isn't going to help.
Mirror and flashlight time or crawl under it.
Old 07-15-2008, 01:29 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Don, look for the casting # of the block below the back of the right head.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 07-15-2008, 10:37 PM
Got it ID'd. I thank you guys for the help.
I would also like to thank the people who put in all the work to keep the informative pages up so that those of us that are new to the addiction can function.
Old 07-16-2008, 12:27 AM
Well tell us what you found.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 07-16-2008, 01:41 AM
greyno3's Avatar
greyno3 greyno3 is offline
Ditto....I love treasure hunting! Left & Right side confuses me, I like drivers side & passenger side when describing parts.
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
