Shifter
Is there a rebuild kit available for the NON Hurst shifters that were I think ITM shifter bodies...Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
ITM shifters were a Camero thing in the 70's.
Firebirds & T/A's (70-81) ALL came with OEM Hurst shifters. The ITM Camaro shifters are readily available on the used market & you should be able to find a GOOD used one for not too much $$$. |
I did not know that bout the shifters for Camaros....thanks 2many
