81 T/A WS6 front rotors same size as regular T/A?
Hi Guys,
I'm new to the 2nd gen stuff. I just bought a '81 Trans Am Turbo WS6. During the test drive I noticed the front brake rotors are warped. Not extremely, but enough to irritate me so I want to put new ones on. Can I get regular rotors that fit just any 2nd gen T/A or are the WS6 ones different? I haven't found any information about the WS6 package that leads me to believe other rotors were used up front. Anybody got a part number for them? Thanks guys! I'll post pictures of the car as soon as I get it home. erik
'67 GTO hardtop coupe 400 2bbl (sporting a 4 bbl) '70 GTO convertible 400/400, matching numbers, Currently getting worked on again, body in the bodyshop, engine at the machine shop etc!!) '71 LeMans Sport T41 Coupe restomod (GTO clone with Judge stripes and wing) 400/350 '71 LeMans Woody Wagon 400/350 patina project 1975 Grand Am 400 factory sunroof project car |
I don't have a part number , but htey are the same as a regular T/A or even a firebird. Personally I haven't had the best luck with aftermarket brake rotors, seem to warp very easily. You may want to look into having your originals turned. JMO
As I recall,the interchange on them is 79-81 ALL F-car (front)
That's what I thought....
Rotors should be the same I think 78 they changed the bearing size per my shop manual, calipers were different about 81 when they went to "low drag" and a quick take up M/C.
I have had good luck using the Raybestos Cross Drilled/Slotted brake rotors
not to mention they aid in giving a good bite the Powerslot rotors i have used, but seem to warp easy i wish there were alimunim hub rotors or a two piece conversion available talk about taking some weight off the car. |
